More sleep, less alco will fix the eyes :banana:
How did you fail last time? What grade sandpaper did you use? What did you do after you sanded to finish the job?
Ive never sanded mine. Just used an old T shirt/ singlet and get good results out of whatever brand polish I have in the shed at the time. Goes from a lightish color with yellow tinge. When finished the headlights look much darker. Only takes 2-3 minutes per side. Repeat roughly every couple of months. I did try meguiars metal polish once but found that just a general general brand polish did just as gooda job.
Edited by l_uk3y
I bought a kit off eBay - little bit of sanding involved but they give you the correct sandpaper. Think it was called glassylite or something like that. Cost me about $30. Headlights look pretty good now.
I stopped at a Bursons store yesterday and noticed they had the same sort of thing for about $50
Likewise. Glassylite kit is the best stuff...comes with sandpaper, cleaner, polish and nano-sealant. Mine are still clear as daylight and it's been about 2 months since I used the Glasslite.
20 months on and mine are clear as. Why not use a SAU Vic supporter in Final Inspection? Get the car detailed, headlights done at the same time and you're good to go.
I still recommend to people, paint polish and a MACHINE, not a 'hand job' will give you the results you really want. Some headlights do require a wetsand if really bad, but most times, you can just attack with paint polish and a machine. Keep them waxed and you shouldn't have an issue for a long time IF corrected properly in the first place.
If the FI gallery wasn't down, i'd show you what can be done with paint polish and a machine ... Damian took some great shots...
SS8, whats a machine..? im not following when you say polish and a machine...
anyway im gonna try again to scub them out a bit this afternoon when it cools down, cause SHIT its hot today... not as bad as yesterday but still >.<!
i might just try toothpaste first ^_^
he means polish it using a machine
i did the lights on my R34. only did a half assed job cause i was just seeing how it comes out and it came out good.
got myself some mild rubbing compount and gave the geadlights a good rub. the grains int he cutting compount cut away 90% of the yellow tinge but after a quick wipe it left the headlight dull. then got some paint polish and rubbed it on the headlight. using a buffer (machine) i buffed the headligth then put a coat or carnuba (sp) wax on it. and its come out awesome. all up each headlight took me 20mins
depending on where your located i can come and do yours for you.
wahhhh
if ur Serious about it ashneel ill take u up on that, im in wheelers hill like 10min away max..
anyway pm'd u
kitten plastic polish and a terry towel. takes a few applications and will fix them right up. Take you 5 minutes. May have to do it every couple of months or so depending. Dont bother with the whole sandpaper bullshit, whole lot of work for no reason
use AUTOSOL metal polish from supercheap auto , any other plastic polish is ok but this kicks ass
pretty sure theres a reason its metal polish and plastic polish
just taking a guess and saying different chemicals in each and could damage if used on wrong application
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
