  • Replies 124
  • 1 month later...
Hey
I was reading ur answer for this not fitting rb25det neo motor, I was wondering why it doesn't fit.
Cheers
Rob
Hey
Cheers
Rob
Hey Rob!
The NEO's have a different engine block set-up, the bolt pattern does not match so extensive modifications would be required.
Cheers,
Brendan
(VM)
  • 1 month later...
Just letting you know that these WILL fit a neo motor. My setup at the moment is an rb25de+t neo using an r33 ecu and running an r33 s1 intake manifold to retain sensors for ecu.
The only thing that's different is you need to pull out one stud for the head and replace with a longer one. I did all the work myself and haven't had a single problem.
Hey!
Thanks for the information, I am only going off what customers have noted however I do know that many have used these on the NEO's with modifications.
Do you have any images of your set-up?
  • 2 months later...
  • 1 month later...
Hi there could you pm me with a price for a raw cast plenum with adapter for an r33 rb25det. Also do these work with the standard fuel rail? Cheers!
Hey,
Will do so now, yep original fuel rail will go straight on no problem.
- Brendan
Hey mate,
Does the plenum take all sensors that were on the stock one? IAC/AAC, vacuum lines etc.
Can you pm me a price for the plain cast finish with stock throttle body adapter to 2750 please
Thanks
Hey mate,
Thanks
Hi,
Yes mate, takes all the original sensors mate! No mods required with this one.
Will PM you now.
- Brendan
Could u please pm me a price for a raw cast aluminium plenum to suit standard throttle r33 rb25det. Thanks bud!
On it's way....
  • 3 months later...
    • That is surely the biggest gathering of Stageas in North America, ever!
    • Remember kids - if you can't afford to buy 2 GTRs......
    • I know people cry at the price of the Getrag 12-14k for a conversion now, but it really is a nice mid point. Not going to get change from 10k on a gearset installed.  $30k++ for sequential.   I know you run the risk of a damaged used one and parts are hard to get but as a street car gearbox its really hard to beat. If you enjoy a more traditional manual, its the choice no question.
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
