Hi,
As the topic states I'm trying to achieve around 260rwkw and just need some advice on a couple of things.
Car: R33 S2
Current:
Std Turbo
Std Injectors
Std AFM
Just Jap FMIC
Apexi AVC-R
Walbro 500hp internal fuel pump
JJR Coils
Toshi re-map
Exedy Heady Duty Clutch (put in 3000kms ago)
3" dump and 3.5" catback with hi-flow cat
Proposed:
S15 480CC injectors
Hypergear R34 OP6 hiflow turbo
Z32 AFM
Toshi re-map
I read in a couple of posts that people had some issues with the Walbro fuel pump but this was mainly with a 450HP one. This one is 500HP and I'm just wondering whether anyone has any experience with this one? What about the FMIC and clutch?
Any feedback would be appreciated.
Thanks
Edited by da spike
https://www.sau.com.au/forums/topic/303588-260rwkw-is-my-goal/
  • 3 weeks later...
Ok I have some questions:
I have sourced the s15 injectors, z32 AFM and just waiting for the turbo to come in from Hypergear.
Can I put in the s15 injectors for the time being and drive the car normally? I read in some posts that it should be ok but I just wanted to double check this.
Also once I wire up the z32 AFM will I be able to drive the car to get it tuned or will it run like a dog?
Thanks guys.
as above just drive it there stock and fit them once you get to the tuners.
on the subject of turbo, why not go the Hypergear Powered Up "PU" hi flow. You are already purchasing an R34 OP6 housing anyway so you may as well get a 0.82 housing.
They have a dyno of one making 269rwkw and 272rwkw on an R33. The R34 OP6 housing looks to make more around 250rwkw.
Edited by Harey
He will make 260rwkws+ on the OP6 with the actuator supplied. The PU high flows are capable of doing lot more then 270rwkws.
Sounds good but what is the cost difference between an OP6 and a 0.82 housing? Seeing as though the OP6 housing has to be purchased anyway as he has an R33.
The only reason I would stay with the standard type hi-flow is to stay legal ie look completely standard from the outside. Once thats changed by using an OP6 housing, I reckon go all the way with the 0.82!
I already had a blown r34 turbo with OP6 rear so I just sent that in to get highflowed :)
I was thinking about getting the powered up highflow but I'll be happy with 260rwkw and no need really, i'd rather a tad more response.
Thanks for the replies guys looks like its getting trailered there.
can drive with 480cc injectors and the standard ecu, it'll run richer and will foul plugs quicker but other than that it wont do any damage. wire the z32 plug into the standard afm wires without cutting them so you have both plugs in there, makes swapping the afm a 5min job if that. car will probably run with the z32 and 480s if you have to limp it to the tuner, just keep it off boost.
I already had a blown r34 turbo with OP6 rear so I just sent that in to get highflowed :cool:
Thats sweet then!
I will prob do the same one day as I would love to keep the exterior of my turbo 100% standard. Keen to see what power you can get out of it!
I am fairly new to skylines but with commodores you could change the injectors within about 5 mins. I once just changed them in the tuners car park. What sort of job is it on an RB25?
I like the afm idea.
It doesnt seem too hard, theres a DIY article about it on here, I dont think its a 5 minute job though lol.
http://www.skylinesaustralia.com/forums/In...mp;hl=injectors
Edited by da spike
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
    • I used to do that (sills with rubber jack block).. ... then I got side skirts, and there's no way for the jack to actually work there, the jack pad itself on the jack is too big. Is the answer to use a... smaller (?) jack? Hmmm.
