  • Replies 846
Posted Images
ah kool not sure who you are exactly but thats kool we'll meet up
you wouldnt, ive never been to a SAU event, been meaning to but always clashes with work etc. but hopefully this time ill be able to get out there
i dont have time to reply to each and every responce but this is the jist of how we sort out who goes
Members that is paid club members get priority
Club sponsor's get further priority over members
after the date that Heslo specified if there are any remaining spots they will be opened up for the general public
i have just gotten off the phone from Luke and i am quiet excited to say the Skylines Australia : SA will be raffling off 1 spot to anyone not just paid members
this raffle will be held at the SA Simulation day further information as its recieved
I'm in if there's spots hopefully, already member
Got a feeling that ain't going to count for shit!
well you would better hope that it does count for something Steve....otherwise its just useless becoming a member in the first place :(
Ok so more information about this raffle
$5 per ticket and that gives you the chance to win your track day free of charge SAU. Sa will pick up the bill for your entry, this is open to everyone buy as many tickets as you like raffle is open from now until 8.15 on the night of the simulation event and the winner will be drawn after the trophy presentation on the night
Please be patient guys myself and heslo dont have jobs at computers so you only get limited information during the day
Members get priority i dont think this needs to be repeated again the length of your membership doesn't matter join today and pay your money first and your spot is secured thats the fairest we can do it
sorry but I think people who have already paid should be getting preference over 'payment pending' people and non members.
my 2c
-D
i agree with dohmar.
i was chasing cash from people and still chasing and then had ppl pull out and no one to replace..
so i think that if ppl pay now there in no matter what..
last thing u want is all these ppl saying yes ill be there then not pay or show..
happened to me and i had to foot the bill..
but if tell me now if im not in coz i will get my money back off damo and organise my own..
cheers
my 2c
-D
hang on a sec
Ive been here on SAU for 5yrs now, very active
I havent been able to afford membership simply because of finances (not working)...
however this track day marks the ideal time for me to officially join the club; not that I can really afford it until bike & daewoo sell,
but nevertheless, payment & membership form sent via post
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
