going to see andrew at am performance this saturday and apart from that another quick check up on the dyno to see if everything is working fine.....and then the car is all ready to be tracked......
- braided brake lines fitted
- new clutch fitted and works awesomely lol
- new qfm a1rm's fitted with penrite sin 600 fluid $20/500ml
- oil cooler installed with a oil + filter changed
- leaks being sorted out now....1 down, 1 to go :(
  • Replies 846
Posted Images
car is at michaels for dump/front/decat.
intake pipe
screamer
then off to jeff on fri for tune at 21psi
then fit oil cooler and relo kit
oil change
hook up my defi sensors
new brake pads
then go fast!
well i am trialing the penrite sin 600 brake fluid for this track day and see how we go there......same with the qfm a1rm's.....got brand new tires on the rear so far fairly happy with them
good boy.
ive got it in the 200 at the moment... ill be switching to motul.
Should i do an oil change before the track day or after...or both?
Always do it before like dave said. I dont do it after, actually i'm still running the same oil i put in my car before Adrain's track day :cool:
Ok, cool. Would it be alright to change the oil 1 week before the event, drive on it a bit, and then do the trackday? Or would i be better off doing it 1-2 days before and doing very little driving on it?
Ok, i may do mine on the Sunday in the morning, then head out to Dion's place in the afternoon - as i am staying at his place the Sunday night as it is closer to leave from there, then Aldinga.
Oil change a week or so before is fine. Its the old oil that isn't great for your engine when it is under stress. The older the oil, the quicker it breaks down and then literally loses its lubricating properties. After a track day is a very good idea too - and if you think about it $70 - $100 to do them both is far cheaper than an engine rebuild.....
Very True...but i could have a lot of fun with an engine rebuild...however, i wouldn't like how much i would be spending.
Question, I may have a mate coming out to watch me make a fool of myself, would it be possible for him to drive my car out on the track if he has a helmet with no one else in the car? Or is there some insurance liability form i have to sign, that will stop him from being able too?
He would have to fill out the forms and pay $200 just like everyone else if there was a spot free.
EDIT: Beaten by Chad
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
