Dale how are we going for those timing gear mate????
I'm not sure on the numbers, i think Luke has missed a few people on the list. I would say that we will get the numbers needed.
The GSR/EVO club are having a committee meeting tonight (I think) and once it has been past the committee then we will have a definite answer. They have hired them out in the past so Matt and Tristan doesn't see there being a problem.
  • Replies 846
Posted Images
well well,
my GTR is nearly ready to rumble:
fit Hawk pads
bleed brakes
new semi's need to be fitted
repair intercooler pipe
fit straight pipe
However the S13 still has a long way to go:
finish the rewire
5 stud conversion
33 brakes
wheels
oil cooler + gauges
tune
Anyone who has nothing to do this Saturday is more than welcome to come swing a few spanners/screwdrivers!
Nigel.
Nigel.
And anyone left over can help me install my automatic sliding gate to the front of my house :)
Thanks!
MY bendix ultimates lasted 20mins at mallala at the front of my stagea, with slotted rotors
the rears with bendix heavy duty are only worn now, 6months later after the track day
got more bendix heavy duty for the rears, and a set of gtr r32 front calipers and slotted rotors, need a set of qfms for them
the car Im taking out, r32 sedan, has qfm a1rm's front and rear. 750degrees should be ok. the bnendix are rated ~400deg
Done some searching seemed to be the way to go anyone in s.a sell them? And roughly know a price?
have a look here
http://www.skylinesaustralia.com/forums/Qf...ak-t301207.html
Edited by DSTROY
Nice these should go good with the new slotted rotors just placed the order.
They are an awesome pad, make sure you bed them in properly and they will bite nice and hard.
Edited by DSTROY
prob last 1 lap :( . mallala is known to b 1 of the hardest tracks on brakes in australia.... listen to wat every1 else is saying bout the qfm's
I can vouch for that. Love the high speed turn 4, then hairpin turn 5. Best opportunity for passing anyone there ... if you've got balls big enough! :)
Unfortunately, the last time I took turn 5, I crashed into another racer who was going way too slow for that turn, and squared the turn off leaving me no where to go. I carried too much speed and committed to the undertake ... unsuccessfully! :D
Yeh I seen others talking of them, would they eat the sh*t out of my slotted rotors? Or will they be ok in them? How much $$ a pad am I looking at?
i am running the qfm a1rm's for this track day....never used them before but they seem to be pretty good value for price....good cold bite and well lets see how it goes on the track....i had mine fronts and rears delivered for $238....and i got them in only a few days after paying......very happy with them so far
im gonna end up runnin outta cash to rebuild my 32 brakes (need pistons and seal kits $400 alone on trade price let alone new lines, rotors and pads aswell) the car currently has ca brakes on it, i lost my licence 5months ago so im not missing this track day, i dont care if i gotta take it easy.
If i take 2 sets of new brake pads out there u think that will be enough? i kno the ca stoppers wont be the best but its better than not driving at all, like i said id rather take it easy than not drive haha.
well the sil is gutted now so its not pulling up a street trim car, and because i havnt driven in 5 months it can go 1 of 2 ways, either ill be slow, or im gonna go all out haha :P
the car will still have good rims and tyres on it, i reccon i can still drive fast and be easy on the brake pedals, its either that or someone sponsor me a grand to do the brakes haha :D
mite just get some bendix heavy dutys, like 1 set for rears and 2 sets for fronts
    • Lets say I wanted to buy this, specifically for this purpose. How do I actually perform the function. Can I still buy a Consult-1? Am I about to be burned by the fact my car is a 2000 model Series 2 R34 and thus will be some stupid other system? Do I just need this -> https://obd2australia.com.au/product/nissan-consult-14-pin-to-usb-ddl-diagnostic-interface-with-ftdi-ft232r-chip/ And with what software?
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
