  • Replies 846
Posted Images
if mine fits you can borrow mine for the day
thank you so much for the offer.
muchly appreciated - we'll be right tho - resoldering bits atm, fixed
found one of the 90mm q45 afm's is broken :down:
so currently soldering wiring plugs directly to stock r32 gtr afm's to make a flawless ecu-afm connection
weather aint looking good for this track day :devil:
might have to invest in some full-tread tyres
rain in Adelaide doesn't always affect Mallala so we should be ok. and "rain" in SA doesn't last for very long (10min?) - wait an hour and the track will be dry again :ph34r:
uh oh...
damn, Ive purchased a dodgy pair of Q45 air flow metres
just wont work no matter how its wired up.
the stocker gtr afms are cactus at the pinout point, might have to cut out the top and solder some wires directly to the connectors
if i cant fix it by mid week means I'll miss my dynotune session; therefore restricted to the stagea
grrr
If you've paid the $200 then yes, that's all that remains. And that gets paid on the day...
That reminds me, the following people have left to pay.
Dave - scandyflick (spoken to me)
Andrew - AMPerformance (money incoming)
Andrew - semislickR32
Martin - HOSTILE
Abe - Aberax (spoken to me)
Glenn - Heslos +1 (money incoming)
Adrian - 4dr Taxi Man (money incoming)
Adrian - rad32 (money incoming)
Do you want to borrow my GTR AFM's Brendan?
thanks so much for the offer
helps me out big time
Ive ordered 1x z32 afm, and will scavenge the z32 afm that is on my stagea and swap that with the working q45 afm.
that'll work
2x z32 afm's for the rb26, and 1x q45 afm for the rb25 (which is tuned via manifold air pressure anyways, afm is used via the piggy-back for voltage readings, clamped via a fuel cut defender)
well, for those thinking about breaking shit on the day, news is looking partly better
my winch is in ;)
now to get the tow hitch done and im set for full recoveries, even onto your hire trailer if need be :P
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
