  • Replies 846
Posted Images
If you've paid the $200 then yes, that's all that remains. And that gets paid on the day...
That reminds me, the following people have left to pay.
Dave - scandyflick (spoken to me)
Andrew - AMPerformance (money incoming)
Andrew - semislickR32
Martin - HOSTILE
Abe - Aberax (spoken to me)
Glenn - Heslos +1 (money incoming)
Adrian - 4dr Taxi Man (money incoming)
Adrian - rad32 (money incoming)
I don't recall having a conversation or sending a pm...unless of course you are talking about my post 1-2 pages back...ie this
Just sent the remaining $100, should be in the account on Thursday.
Martin - HOSTILE
semislickR32: Money Incoming. Finally! :D
ku36 are around $180 ea delivered from Option One garage, QLD, for 17x235's
They are on my track car ready and unused, as are the A1RM track pads, however I wont be able to bring the track car out
Will be in the stagea
KU36's are $275 each when you're talking 275/35/18s
Ok,
Can i get confirmation from these people that they still want the timers
(i don't want to be left out of pocket on this).
Aberax
Destroy
semislickR32
Tangles / writeoff (Share)
Scandyflick
BIT SUS
Krishy
4dr taxi man
HELSLO
Josh (What's his username)
Heslo
Heslo's +1
If people want to pay before hand them send me a PM and i'll send you my bank details.
Ok,
Aberax
Destroy
semislickR32
Scandyflick
BIT SUS
Krishy
4dr taxi man
HELSLO
Heslo
Heslo's +1
Yep, i am still up for this.
yes from me, although it isnt important for a good day out
dont you lose $ on it mate
+1
should i spend $1024 on 2x new toyo R888s
or spend $1100 on 4x Kumho KU36's ???
*watches weather forecast....*
I'll be running R888's cos i have no other tyres to use. Been heaps busy lately and haven't even started to get my car ready. Got to install front camber arms and get an alignment, fit new brake pads and install roll cage, mount rear wing, change oil and hopefully thats all. Also haven't received my CAMS licence yet that i paid for ages ago :)
Dale im still keen on the timing gear.
Edited by DSTROY
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
    • Hi Everyone I am from West Pennant Hills in NSW. Been too busy until recently to attend to my RB25DET Series 2 engine until recently. I am planning to stick it into the S15 shell at this stage, unless a nice SR20DET turns up... For now, i am going to try and get the RB25 running and working well then decide what gearbox to use. My preference is to retain the SR20DET  6 speed gearbox and tail shaft to retain as much and least modifications as i can avoid. I am an old guy and won't be doing any heavy drifting so i don't need a bullet proof gearbox Does anyone have experience with starting the RB on a stand? I got everything setup as much as I can with the info i can find... endless searching and videos on Youtube I would be great to get some pointers Cheers Songo
    • Hey all, Recently have had my s1 r33 gtr serviced and noticed my coolant reservoir was topped up to the max line. Took the car out for 1 yesterday and noticed today the reservoir is completely empty.  Any ideas? Radiator is full
