I use the Light Wheel Alignment in town. They use old school analogue equipment and specialise in wheel alignments ie that is all they do. I find them better and more accurate that any tyre retailer that uses digital equipment.
58 Byron Pl,
Adelaide, SA 5000
ph: (08) 82121448
https://www.sau.com.au/forums/topic/304368-wheel-alignment/#findComment-5040590
Adelaide Radial Tyre is THE place - and is about 2km from you on North East Road, Holden Hill opposite Hungry Jacks
+1 here. Im due for a rotation and alignment, gotta see Daryl and the boys soon!
https://www.sau.com.au/forums/topic/304368-wheel-alignment/#findComment-5040593
58 Byron Pl,
Adelaide, SA 5000
ph: (08) 82121448
That's who I used on my R as well Dave......experienced blokes that know their stuff and are extemely accurate.
These guys specialize in alignments, most tyre places will do alignments but that's just like taking your ride to K-Mart for a $99 Service & Tune special........you get what you pay for.
https://www.sau.com.au/forums/topic/304368-wheel-alignment/#findComment-5040902
they also own the store @ handcock rd and north east rd
i use bob jane's on main north road in prospect.....always did a good job and never had a problem and he is cheap as well
you've got to be kidding
https://www.sau.com.au/forums/topic/304368-wheel-alignment/#findComment-5041307
heard nothing but good things about them...
Jack Bakers Tyre Power is who I've used everytime for my car and the old mans.
http://www.jackbakertyres.com.au/
another one here for Adelaide Tyrepower at mile end :D
... but im a tyrepower fan boy. lol.
https://www.sau.com.au/forums/topic/304368-wheel-alignment/#findComment-5041354
+1 that Place will take care of u mate. Had a few friends who went there and leaving with happy faces =D
Edited by kb-r33
https://www.sau.com.au/forums/topic/304368-wheel-alignment/#findComment-5041944
