Hi
If anyone can shed some light on the below and give me some advice, that would be grand!
So, i've had it for 5 or so months & it's a 93 R32 gts-t running 12psi
Mods:
Fmic
3in exhaust
bov
pod
Recently had 100k service done, spark plugs changed, & new piping on the intercooler as the old ones were cracked, leaking air & giving no boost.
Car has stock ecu & is yet to be tuned.
My troubles:
1.When either in boost or not(generally not), power will cut up to a second, then re engage. Mostly when the car is a little colder, but does do it when warm.
2. If i go to change gears, but don't & just let it hang in nuetral, instead of dropping back to just under 1grand it will either stall, or stutter and then even out.
3. Recently a few times when stationary car has rev'd itself then hit 0 and either regained and trys again or stalls
Rev's ocasionally seem to sit above 1grand then eventually evens out and rests at just under.
Cant say my knowledge on cars is very high so please excuse my noobness. :)
Possibly due to it needing a tune?
Thanks for your help!
Simo
https://www.sau.com.au/forums/topic/304561-r32-gts-t-problems/
2lv - do u mean bov leak?
Yeah i could be looking at getting a new afm - my mechanic says not much point in cleaning the afm as it will chew away at the plastic on the rod or something like that. Any truth in that comment?
Simo
    • Hey crew, Failed my WOF cause of a lower control arm, and I've decided to hit both arms, and also the compression rods at the same time(seems they're gonna be the most likely upcoming failure points from some discussions with the lads over on the G35 reddit). I've looking at these form Z1:  https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-compression-rod-p-40716.html https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-lower-control-arm-p-40674.html I asked Z1 if they'd work as it's the same platform, just RHD vs LHD. I basically got told "Lol dunno". Specifically they aren't aware of any difference but can't guarantee fitment as they haven't done it on a 350GT. So guess I'm asking is if there is any issues with using 2005 G35 coupe suspension parts on a 2005 350GT coupe? Orginally I thought it could be something in the way of the arms that each control arm is designed to be positioned around, but that'd be an engineering nightmare for Nissan needing two different shaped control arms 😅
    • ^ This. The mode door actuator is a common failure, as is the actuator and/or the actual valve for the coolant flow control valve. I also don't know how available the mode door actuator is these days. I've been meaning to look into it and get one from wherever is possible, to keep in the shed for the rainy day when mine eventually fails. Anyway, the advice to you is to search the usual NOS part supply places, or even just go to Nissan and see what they list.
    • Have you got a pic of the actuator? My guess is that unit has failed internally and was flopping around, so the previous engineer who owned it forced it to be fully open to cold air (blocking the heater core path). As far as you can tell, is anything else wrong in the system? Likely you just need a new actuator (not sure how available they are) and then "installation is the reverse of disassembly"
    • I'm happy with the Lsailt unit that I put in, it puts full Android on the top screen so you can run whatever Nav and other Apps you want, while still existing inside the factory functionality like automatic reverse cams, audio input switching, retains factory bluetooth etc. Not cheap and the install was moderate (not simple, not hard) Yours is a V36 not V37 though right?
    • Yeap, all the NC's that I originally looked at that had a hard top were PRHT, which makes the roof line look horrible, hence why I said nope to them My only caveat for another MX5 was it needed to have a hard top, and initially I didn't think you could get a detachable hard top for the NC,  like my NB had Again, a big thanks to Matty for helping me source the detachable hard top for my little girl, they are as rare as hens teeth in Australia, and the few people who have them, keep them Also to Greg, for initially pointing me in the NC direction NC PRHT 🤢🤮 Not mine (I really should take more photos of my car), but a NC with the detachable hard top 😁 To me, the difference in how the detachable hard top roof line looks, and how it actually follows the bodies lines, like they do on NA's and NB's, is chalk and cheese compared to the bulbous looking PRHT
