Hey guys. Just wondering when people have upgraded their turbos what they have done with the pipe work between the turbo inlet and the AFM.
My Hypergear turbo has a larger inlet then the factory turbo (kind of makes sense really :) ). Now I am quite animate about wanting to stick with the factory Airbox and not a podfilter for legal reasons. Now if I can stick with the factory rubber intake which would be preferable I will be chopping the AFM side to add a metal intake.
So i guess the 2 issues im seeing is that I need to find some form of soft adapter to go over the turbos inlet. Then drop down in size to a hard inlet for the rubber pipe. I can see this is easy on paper. But in reality I will probably hit some drastic space issues.
What have you guys been using? Or does nobody make any effort to retain the airbox these days? (Even though half my engine bay is painted or being polished. I would like it to actually be an effort to find the defects and not just scream out at them.
Cheers for any help.
Luke
https://www.sau.com.au/forums/topic/304597-pipework-between-turbo-and-afm/
Just make a metal intake pipe first it will be better because it will be 3 inch and second its metal so no chance or getin sucked shut on hi boost , ive made my custom pipe modelled on the stock one and am still using th airbox
+1 If the turbo intake is 3 inch you should run that size through to the airbox.
Alloy or stainless and paint it black if you want the stealth look, although its legal I think as long as you do keep the factory airbox and afm.
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
