Hey guys,
I'm getting my Kumho's fitted tomorrow, but they've been sitting in my garage for a month or two and have collected a couple of spiders. I removed most of the webbing, but there's some stuck in there. Should I just hose them out and let them dry, or will this damage them somehow? Do they need to even be cleaned, or will the tyre joint clean them for me?
Tyres seem pretty durable, but I figured I'd ask here before I went a head and potential ruined them.
Cheers,
Kieran.
https://www.sau.com.au/forums/topic/304777-tyre-mantinence/
Washing your tyres wont damage them in any way, especially if they are just street tyres... You can even use regular every day washing chemicals (as long as they arent caustic).
Just use tap water and Morning Fresh and they'll be fine. :D
https://www.sau.com.au/forums/topic/304777-tyre-mantinence/#findComment-5046672
LOL u drive over water and so many other things on the road so how can this be different?
its all good man wash/wipe it
and what kumho's are they?
if they are ecsta supra's then i would not put them on as i have them on front and when driving in the wet, taking a roundabout at 20k/hr i get understeer at times
https://www.sau.com.au/forums/topic/304777-tyre-mantinence/#findComment-5048255
Was referring to cleaning the interior of them more than anything. Was unsure if they had some sort of special coating or something, figured I'd ask just in case.
Thanks anyway.
https://www.sau.com.au/forums/topic/304777-tyre-mantinence/#findComment-5048280
The inner liner of normal street tyres can be affected by chemicals if they are caustic or corrosive , such as degreaser or turpentine etc.
Just use a cleaner that doesn't contain anything too acidic and it shouldn't harm the inner liner at all.
P.S. - Don't use a brush or anything that could tear the liner (its only very thin), just use a soft sponge or rag. :)
https://www.sau.com.au/forums/topic/304777-tyre-mantinence/#findComment-5050346
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
