Currently have a surge setup with a Carter Gold lifter - 2.5lt surge and 2 x 044 Bosch fuel pumps and Turbosmart rising rate reg.
Full braided lines and speedflow fittings, 4 Indy blue 1600cc injectors. Motec M400 running gear.
Just looking for peoples experiences in running methanol using these pumps, whether its a 50% mix or a 90% mix and information would help.
This system has handled E85 (15% 98RON) ELF branded ethanol but looking for a different option as right now as meth is alot easier to aquire in my area, that and the fact that ANDRA have banned E85.
Have been told to upgrade to a magnafuel pump but not sure which one, reccomendations?
Thanks,
Gary
Edited by Parag0n
https://www.sau.com.au/forums/topic/304798-044s-methanol-tolerant/
Just double check that your braided lines are ok with methanol.
and depending on your power level you may need another pump, most methanol big power drag cars run a big mechanical pump becuase the electric pumps cant flow enough unless they have half a dozen pumps in the boot.
If you are running methonal and have a check valve after the pump I believe you have to make sure it is meth compiant too. I got a Speedflow check valve and was instructed to change an O-ring in the check if running meth, it is supplied when you buy one.
Fair enough, anybody had any experiences?
I'm talking about straight meth yes, not a water/meth injection etc
Have a look at what all the Pro Turbo cars start and idle on. They have an 044 in line for this purpose.
  • 1 year later...
Just doing some thread mining about methanol, I will be getting a E85 tune done on my new engine and was thinking about what extra gains I would get running on methanol.
Im running 2x 044 pumps so I guess that would be the limiting factor when using methanol as they wont flow enough...?
quadruple your fuel system for meth from 98.
your gonna need 2400cc injectors for 850hp, base on your 475rwkw figure i reckon 550-600+ on meth
so 850hp @ 88% duty with BSFC of 1.4 works out around 2360cc
I have 2000cc injectors now so would need a few more pumps then.
Just thought meth would be a cheap option over drum E85 and C16 type fuel
Also, will the 044 pumps handle methanol..?
Edited by WHITER33GTS-T
    • I'd be worried about having to parallel park a boat like that. Magnificent car though.
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
