Hmmm, looking at it again, I think they should have done a full re-skin of the tailgate if they wanted any chance of the lights looking anything near to a factory job.
Overall, that's probably my biggest issue with the car, and I hate mods that look like an afterthought. The way they've just covered the standard Stagea lights and then kinda "thrown" the C10-style lights on over the top is the main thing that makes it look crapola...
https://www.sau.com.au/forums/topic/305310-styling-crime/#findComment-5052341
Looking at the comments after the article, it seems I'm not the only one who shares this view.
No you're not,The car's attractive, the lights just look kinda photoshopped,especially on the back,,side on, just looks like someone smuggled a stagea onto the back
https://www.sau.com.au/forums/topic/305310-styling-crime/#findComment-5052557
The front looks alright but the rear just looks like it's rushed
But Hanso is right, these two cars do go together
WTF. Do you mean they dont go together?
Sacrilidge(see dictionary for meaning). This thread should be destroyed and never spoken of again.
As stated before it is an insult to two great cars.
Anyone with eyeballs in their head would know this would not work.
Y30 Cima wagon conversion? I think so.
https://www.sau.com.au/forums/topic/305310-styling-crime/#findComment-5053436
How could they???
Just doesn't fit as imo. Sacrilege!
Here is a pic of my KGC10's nose and there is no way it is going anywhere....
I agree dude the KGC10 and P510 or two of my favorites. Has anyone checked this magazine or site out?
http://japanesenostalgiccar.com/index.cgi?section=magazine
Interesting. Old skool rides. One powerball... :P
Ive just noticed, nice refernce to Prince motor Company, in your username.
Edited by dirtyRS4
https://www.sau.com.au/forums/topic/305310-styling-crime/#findComment-5082394
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
