Recently purchased a GTR cooler for a project car. I was initially purchasing it for test fitting, however after a little research, and then actually seeing the condition of the cooler, I have decided that I may actually use it.
What I want to know is how can I tell what model GTR it came from? The owner honestly had no idea what model it was from - and I wasn't complaining with the price it was purchased for.
I am assuming that the R34GTR cooler will be 'better' than the R32.
Cheers,
Tim
https://www.sau.com.au/forums/topic/305382-gtr-intercooler-differences/
R32, R33 and R34 GTR intercoolers are very similar, if not the same.
R32 and R33 GTR intercoolers are the same.
R34 has a temp sensor on it, but size wise I think is the same.
GTR FMIC's are all good for 300+ kW's.
The intercooler core should be 60mm's thick, if so then it's from a R32 or R33, (R34?) GTR
R32 and R33 GTR intercoolers are painted black and the R34 GTR intercoolers are non painted.
Cheers,
No sign of a bung or similar for a temp sensor, and it is painted black (looks factory) so it will be R32/R33. Picture of the cooler below.
It has a "Calsonic Racing" sticker (part number) near the top right hand corner - no idea if this is coincidental/suppose to be there?
Cheers,
Yeah that looks the same like my intercooler.
I recognise the mounting positions, cuz I took my front bar off to paint strip my FMIC back to bear metal.
"Calsonic Racing" make parts for GTR's, my radiator has a "Calsonic Racing" sticker on it as well and a number.
Nissan might have got "Calsonic Racing" to make the intercooler, but I did not notice any sticker on mine, but it does not really matter.
Yeah, looks factory from the paint and either way it is a GTR intercooler and does a top job.
What project car you building?
Actually converting a 1993 Mitsubishi Lancer coupe to awd. Then using the engine/running gear etc. from an Evo 3.
Limited space behind a front bumper and the curved end tanks lead me to the GTR cooler. I originally got my hands on a JustJap (or JJ styled) 100mm thick core I/C, but there was no way that it was going to fit behind there!
Damn!
A turbo Lancer GLi Coupe!
The car is so light (I have a Lancer coup too, 2001 model) + the performance and AWD, that would be so fun.
100mm is very thick, that's the size of a TRUST Drag intercooler.
Could you have used an EVO FMIC?
But yes I can see the GTR FMIC curves and would probably fit nicely behind the front bar...
How do you convert a FWD to AWD?
Modify the FWD system with a Drivesharft to the rear diff?
In a nutshell, remove the entire rear floor pan and replace with the awd one (the standard lancer boot floor isnt raised to accommodate the rear diff.
Other than that the only 'structural' items are:
- welding in the rear diff support hanger bracket (runs in-between the chassis rails and is what the rear diff hanger bolts up to).
- welding some captive nuts in to the chassis rail for the rear crossmember (the standard lancer has blanks where these are to be welded in)
Everything from there on in is 100% bolt up! Then finally get the tail shaft shortened by 51mm and off you drive with some turbo awd goodness :(
GTR coolers will do 350rwkw.
I would be surprised if your little 4G will reach the limits of a GTR core :)
We'll see how far we can take the little 4g! After speaking with a couple of GTR lads locally; one whom is putting down just under and the other just over 600hp at the treads, I was more than happy to give one a try. These days people are all too eager to "upgrade" some of their OEM parts with china-spec of unproved parts - even when these factory parts are more than capable :(
I see,
Post pics when done!
Hehe!
R34 GTR coolers have, will do, 380rwkw easily enough. So a good upgrade for a GTS-T, no doubt.
However - the issue stands as this. For upto 300rwkw, your typical Just Jap and similar cores are a wiser choice for the following...
They come in kit form, with all the piping and so on. Im pretty sure there is a non-reo cutting return-flow style one (someone will know the maker)
By the time you pay for the GTR core, then custom piping, it's getting rather expensive for 280-300rwkw when there is a off-shelf product for half the price.
If you have a standard motor, 260-280rwkw - cost vs the gains i reckon the JJR (and similar) replacement/return flow stuff is really good value these days.
Anything more than 300rwkw then yes, i would say go down that route with a R34 core.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
