Scott fitted the Brembo brake package for me today, pretty much a bolt on affair with the calipers...used an angle grinder to hack off the dust shield in the rear.
350z Brembo calipers (F&R)
RDA slotted rotors
HPX pads
Stoptech G35 braided lines
the front braided lines had to be fiddled around with in order to get them fitted correctly and not hit/rub/scrub against the wheel. The rear lines fitted fine.
Bled the brakes and refilled with Nulan DOT4 fluid.
The Good: looks nice...brakes seems much grabbier when engaged.
The bad: brake travel shot to hell. In order to engage the brakes I had to depressed them fully or pump them. Scott thinks either a bigger master cylinder is needed, or a rebleed is needed.
Made an interesting drive down to Portsea tonight. Was pretty scared I was gonna stack...
Edited by ironpaw
  • Replies 129
Gets shorter. After a few pumps the brakes feel good.
As Duncan said...more than likely ableeding issue....I had issue's bleeding mine when I put em on as well. Took it for a test run with and on the second big hit they were fine.
I had no issues bleeding mine, these are a weird setup as the callipers run twin bleeders. Is there a particular method I should be using on the Brembos? We flushed the whole system and I bled each nipple until there was no bubbles, starting with the inside ones. Then I did them all again to make sure. Perhaps there was an air lock somewhere?
Hopefully any excess air has worked its way into the callipers, I will re-bleed the system for you tomorrow if you like.
your also supposed to either disconnect the battery or unplug the abs module
if you got any air in the abs you may also need to cycle it too (something that is done from the nissan diagnostic thingo)
craigs 'big hit' may have moved some of the bubbles from the ABS module to the caliper.
ironpaw, keep an eye on the front brake lines. one of mine moved and rubbed on the front driveshaft and started wearing out the braiding. so maybe double the cable ties
Scott rebled the brakes. Got a a couple more bubbles out. Pedal travel is pretty much similar to stock now...which is better but I'd think with all the stuff I installed the brake travel would be much less...
hmmm maybe I need to take a big hit with it...LOL
maybe a new master cylinder?
It's the total area that the master cylinder has to move that might make a longer pedal. Single piston calipers tend to have very large pistons. Best way to tell if the master cylinder is not OK is to measure the standard and new pistons and see how much larger the new ones are. Often the difference is minimal because it is the calipers that are larger not the pistons inside them.
And basically, bleeding after replacing everything can be a real PITA. Sometimes it is OK straight away, sometimes it will need a few shots.
A properly bled braking system should have a short pedal travel to get the pads to the disc, and then be consistent pressure all the way to the bottom. You should get the same feel on every push.
If it gets better after a pump or 2 you probably still have air in the system. If you get to the bottom and it sinks slowly you have a leak somewhere. If it is consistently long you have bled it OK and may need a larger master cylinder
nah......my peddle is perfect....doesn't need a new master cylinder.....if it's still soggy you still have air in the lines.....did you do rears as well? If not have you ever bleed the rear?
Scott rebled all four brakes.
Its better now but if I pump it the peddle feel gets better.
Found out on 350z forums that the master cylinder between brembo and non brembo 350z's are the same: http://www.350z-tech...ap-brakesmg.jpg
The difference is the brake booster?
is it even possible to replace the brake booster?
Danny said he never replaced his master cylinder but he didn't mention whether his peddle travel improved either....
found this: http://cgi.ebay.com/ebaymotors/06-Nissan-350Z-PWR-Brake-Booster-Master-Cylinder-R4376-_W0QQcmdZViewItemQQhashZitem43a4829cc4QQitemZ290522832068QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
Edited by ironpaw
found this: http://cgi.ebay.com/...sQ5fAccessories
I am pretty sure Chris(Akebono) and Ben(Brembo) have not replaced there master cylinder or brake booster either.
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
