RB25DET Neo Vs RB25/30
47 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 45
I used to run a built RB25 in my HQ (auto box) making 280ish rwkw @ 20psi. It was very fast once on boost (GT3082R) but it was still relatively laggy with this turbo. I then built a RB30 bottom end and matched it to the same turbo, the car made more power @ 18psi and 1000ish RPM earlier. It was the best decision I ever made and I absolutely regret wasting my money on building the original RB25. The 30 is just so much smoother and nicer to drive. So much power and torque down low and it just pulls and pulls and pulls. If I could do it all again, I would go straight to an RB30 bottom end... Especially on a street car when low RPM cruising is essential. I'm now running a GT3540 and it still makes boost earlier than the 25 with small turbo and its a billion times better to drive. Thats my experience :P
How about all those Supras, RX7's and Big V8's running 800rw/hp with 9-10sec passes that are all RWD?
I think it comes down to decent suspension, tyre setup and launch control.
From what I have read, the RB25/30 will be a great street/drag combo however just waiting to take a drive in Dave's car to see how the new RB25 + turbo setup goes :worship:
Edited by QRI05E
Hmmm I await your impressions QRI05E, I'm in the same boat as ya, got a r33 gtst s2 bone stock (engine wise) and looking for idea's xD. alas the age old debate, rb25 or rb30/25....plus being in nrth qld limits my engine builders down a bit.
any suggestions onto who does 'mail in' engines? I'm doing research ^^;
Nothing stopping you shipping the engine/bits down to them to get it built.
Bubba, missed that post will pm you some.
Spoke to Adam my tuner today and here is what we have decided.
Stock RB25DET Neo
- High mount twin scroll manifold
- Garrett GT35R with .82 rear
- Bosch 040
- 800cc injectors
- SARD FPR
- FMIC
- Greddy Plenum
- Q45 Throttle
- Full exhaust
- Haltech E11v2
Should see easily 300rw/kw
Drive around for a while... then when I need more power... RB25/30DET with the same setup should see 400rw/kw
twin scroll manifold with non twin scroll rear housing on the turbo?
i am not sure if a 040 will support 300-400kw, you may want to look into using a 044 instead.
forget the sard fuel pressure reg waste of money, 800cc injectors will outflow a GT35R @ stock fuel pressure.
Agreed.
That, and with that turbo, why not throw an RB30E in there, run less boost, make more torque and earlier, and have a much more streetable setup?
I will be throwing in the RB25/30 in there eventually... just didnt see the point of ripping out a perfectly good engine. The reason for the GT35R is to that when I do decide to build the RB25/30 I wont need to update the turbo.
Would a T04Z be overkill? Im thinking about the new Garrett GT3788R... Any ideas?
What's the resoning behind changing the throttle body exactly?
All it'll do is hard throttle control. Not like the factory unit doesn't flow enough, everyone else has made 380rwkw out of it easily enough.
From what I have seen, all the 400kw+ RB's switch to a larger throttle but we'll see how we go.
Will I run onto any issues with the RB25 Neo head on the RB30? I have read a few posts with people running into a few issues such as the bolting up a Greddy plenum with the factory thottle body.
Edited by QRI05E
Where have you seen this exactly?
Just because people change a part, does not mean it's a requirement or needed. Some people just get caught up in what they get fed.
recent thread come up about this actually!
http://www.skylinesaustralia.com/forums/La...dy-t291471.html
R31Nismoid - Thanks for the info, like I said, i might just wait and see how we go.
Anyone used a GT3788R on a RB25 yet?
If youwant streetable response, look at the GT3076 or the 3082.
When that gets thrown on the RB25/30, you'll have an unreal combination that will NOT have to be revved, but will be able to when needed.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
