Cartman Posted January 26, 2010 Share Posted January 26, 2010 hey all just got a couple of quick questions as i'm slapping together a rb2630 out of parts i have laying around... the plan is to slap one of my 26 heads i have laying around onto a good condition standard rb30e bottomend i have aquired.. i have everything laying around for this except for the timing belt kit and my head bolt/stud issue.. my main question is about the head bolts/studs considering the 26 runs a larger size... Will there be any problems with me just using arp rb25 head studs? with out getting anything else even tho sleeves to sit in the 26 headbolt holes to comensate for the narrower head stud would be ideall... but this is a very very budget slap together out of parts i have laying around unless there is somewhere i can buy those sleeves providing they arent to costly... OR would i be better to take the complete short block into the machine shop and see if they'll drill and tap it with out pulling it apart (i dont think they'll like that idea ) Thanks in advance Wazz Link to comment https://www.sau.com.au/forums/topic/305599-ultimate-budget-slap-together-rb2630det/ Share on other sites More sharing options...
R32 Driver Posted January 27, 2010 Share Posted January 27, 2010 You can use rb25 studs as some guys here have, no modifications to the rb30 holes Sure you dont want to freshen up the bottom end b4 u slap it together? Link to comment https://www.sau.com.au/forums/topic/305599-ultimate-budget-slap-together-rb2630det/#findComment-5056268 Share on other sites More sharing options...
Cartman Posted January 27, 2010 Author Share Posted January 27, 2010 You can use rb25 studs as some guys here have, no modifications to the rb30 holesSure you dont want to freshen up the bottom end b4 u slap it together? nah.. no need to freshen it up.. this is just a slap together out of boredem, motor was in good working order with good compression before it was pulled out... only reason it came out was for a 2530det to go in spoke to the machine shop today and they've said just use 25 studs aswell as the head is doweled so there shouldnt be any problems with slop in the head Link to comment https://www.sau.com.au/forums/topic/305599-ultimate-budget-slap-together-rb2630det/#findComment-5056688 Share on other sites More sharing options...
Adriano Posted January 27, 2010 Share Posted January 27, 2010 Are you going to complain about sloppy head? Link to comment https://www.sau.com.au/forums/topic/305599-ultimate-budget-slap-together-rb2630det/#findComment-5056756 Share on other sites More sharing options...
The Mafia Posted January 27, 2010 Share Posted January 27, 2010 Just do what I did and order a set of Durapro Bolts. Cost me $50. Nissan quoted $180 for a set of standards.. The Durapro and Nissan bolts are the exact same torque settings. The engine builder said they may even be the same bolts. Link to comment https://www.sau.com.au/forums/topic/305599-ultimate-budget-slap-together-rb2630det/#findComment-5056998 Share on other sites More sharing options...
Cartman Posted January 27, 2010 Author Share Posted January 27, 2010 Are you going to complain about sloppy head? meh just flip her over do the job yourself and be done with it. Link to comment https://www.sau.com.au/forums/topic/305599-ultimate-budget-slap-together-rb2630det/#findComment-5057220 Share on other sites More sharing options...
Cartman Posted January 27, 2010 Author Share Posted January 27, 2010 Just do what I did and order a set of Durapro Bolts. Cost me $50. Nissan quoted $180 for a set of standards..The Durapro and Nissan bolts are the exact same torque settings. The engine builder said they may even be the same bolts. nah, goin studs. Link to comment https://www.sau.com.au/forums/topic/305599-ultimate-budget-slap-together-rb2630det/#findComment-5057221 Share on other sites More sharing options...
unique1 Posted January 28, 2010 Share Posted January 28, 2010 as said above why bother with studs? waste of cash if its just a budget setup. Ive done 2 setups similiar with just rb25 bolts and they are fine. Link to comment https://www.sau.com.au/forums/topic/305599-ultimate-budget-slap-together-rb2630det/#findComment-5058687 Share on other sites More sharing options...
jangles Posted January 28, 2010 Share Posted January 28, 2010 stock h/gasket and bolts are good for up to 6-700hp thats from the keyboard of arguably the worlds best RB30 builder Link to comment https://www.sau.com.au/forums/topic/305599-ultimate-budget-slap-together-rb2630det/#findComment-5058813 Share on other sites More sharing options...
jangles Posted January 28, 2010 Share Posted January 28, 2010 (edited) double post Edited January 28, 2010 by jangles Link to comment https://www.sau.com.au/forums/topic/305599-ultimate-budget-slap-together-rb2630det/#findComment-5058828 Share on other sites More sharing options...
STATUS Posted January 28, 2010 Share Posted January 28, 2010 use new studs, i can tell you now reused ones fail. We tuned a 250000km $150 wrecker NA rb30e (still single cam) @ 22psi (300rwkw) and the brand new gasket failed due to poor clamp pressure (pushed into coolant channel) fitted new studs and it has run like a charm. Link to comment https://www.sau.com.au/forums/topic/305599-ultimate-budget-slap-together-rb2630det/#findComment-5058842 Share on other sites More sharing options...
Duncan Posted January 28, 2010 Share Posted January 28, 2010 spoke to the machine shop today and they've said just use 25 studs aswell as the head is doweled so there shouldnt be any problems with slop in the head good call. bolts job is to clamp, dowel's job is to locate. should be fine Link to comment https://www.sau.com.au/forums/topic/305599-ultimate-budget-slap-together-rb2630det/#findComment-5058846 Share on other sites More sharing options...
Cartman Posted January 28, 2010 Author Share Posted January 28, 2010 use new studs, i can tell you now reused ones fail. We tuned a 250000km $150 wrecker NA rb30e @ 22psi (300rwkw) and the brand new gasket failed due to poor clamp pressure (pushed into coolant channel) fitted new studs and it has run like a charm. nice work trent thats goin to be about what i'm aiming for out of my 275000km running fine rb30e, 10cm t67-25g should be lots of fun on it Link to comment https://www.sau.com.au/forums/topic/305599-ultimate-budget-slap-together-rb2630det/#findComment-5059157 Share on other sites More sharing options...
Cartman Posted January 28, 2010 Author Share Posted January 28, 2010 good call.bolts job is to clamp, dowel's job is to locate. should be fine they put it almost identically to how you've worded it there, i have a feeling this budget slap together is goin to make for some good fun Link to comment https://www.sau.com.au/forums/topic/305599-ultimate-budget-slap-together-rb2630det/#findComment-5059163 Share on other sites More sharing options...
T04GTR Posted January 29, 2010 Share Posted January 29, 2010 shouldnt be sloppy. unless the dowls are missing. Link to comment https://www.sau.com.au/forums/topic/305599-ultimate-budget-slap-together-rb2630det/#findComment-5060895 Share on other sites More sharing options...
Cartman Posted January 29, 2010 Author Share Posted January 29, 2010 shouldnt be sloppy. unless the dowls are missing. yeah they wont be lol Link to comment https://www.sau.com.au/forums/topic/305599-ultimate-budget-slap-together-rb2630det/#findComment-5060958 Share on other sites More sharing options...
cm712 Posted January 29, 2010 Share Posted January 29, 2010 What do u mean by sloppy ? Link to comment https://www.sau.com.au/forums/topic/305599-ultimate-budget-slap-together-rb2630det/#findComment-5060966 Share on other sites More sharing options...
