R34 GTR V-spec 1999
Car was bought by me fresh from Japan a couple of years ago. Only had HKS exhaust when it arrived. All parts bought by me brand new and fitted.
Was recently featured in Performance Imports magazine "Best of the Best Issue"
Mods:
* OS Giken Cam Gears
* Garrett 2860-5 Turbos
* HKS SPL Hard piping
* HKS Power Flow Pods
* Nismo Fuel Pump
* Turbosmart Fuel Regulator
* Hypertune Fuel Rail
* Siemens 610cc Injectors
* Splitfire Coilpacks
* HKS EVC 6 Boost Controller
* Vipec V44 ECU
* Tech Edge O2 Controller
* HKS Front pipe 3.5 Inch
* Metal Cat 3.5 Inch
* HKS Reap Pipe 3.5 Inch
* HKS Hi Power Muffler
* Trust Clear Cam Cover
* Hi Octane Oil Catch Can Kit
* Trust Clear Cam Covers
* Greddy Air Diversion Plate
* HKS Billet Oil Cap, HKS Raidator Cap
* Nismo Twin Plate Clutch
* Project MU Brake Pads
* Tein Monoflex Coliovers
* Greddy Strut Brace
* Work Meister S1 19x10 +10 Wheels. 93mm Dish Front Wheels. 110mm Dish rear Wheels
* Work Wheel nuts
* Dunlop Direzza DZ101 Tyres
* Nismo copy side skirts, rear pods
* Nismo clear Indicators
* Nismo Dash
* JVC Head Deck
* Window Tints Doors
Could have left some out but I think thats most of it. Also has the best number plates imaginable!
All tuning by Scott at Insight Motorsports. Last Tune was 301AWKw at 1.4 Bar. Cam Shaft upgrade will see 350AWKw but its quick enough for me as is.
New Wheels:
Interior
Price: $65K. Location: Newcastle NSW
https://www.sau.com.au/forums/topic/305615-r34-gtr-v-spec/
  • Replies 50
i can vouch for this car... its an absolute rocket, handles on rails, and stops on a dime.... but comfortable, quiet, and sedate enough to drive around.
its a very, very regretful sale, but the new owner will be stoked for many years to come.
good luck shmuck.
https://www.sau.com.au/forums/topic/305615-r34-gtr-v-spec/#findComment-5056299
I never thought i would see the day.
Have seen this car in the flesh, was used as a display car for the 10th Anniversary R34 GT-R Cruise, and suited the part perfectly!
Good luck with the sale Che, as Linton said, the new owner will be extremely stoked with the purchase
https://www.sau.com.au/forums/topic/305615-r34-gtr-v-spec/#findComment-5056324
Ummm Wedding present? lol :down:
This car is awsome, but please don't sell before November lol
Let me know if it goes champ, as i will have to find something ummm almost as good.
Good luck matey. if i had it, i would come a knocking.
Somebody buy this car.
Cam
https://www.sau.com.au/forums/topic/305615-r34-gtr-v-spec/#findComment-5056815
Thanks for all the comments guys.
Killer to let her go but its the right thing to do by my family at the moment. Will see what happens. Might throw it up on carsales in a few days or so. Wanted to give SAU people first crack at it.
https://www.sau.com.au/forums/topic/305615-r34-gtr-v-spec/#findComment-5057421
how can wheels with exactly the same size and offset have different amounts of dish?
Easily with Meisters which is very handy to clear big brakes at the front. They use 2 different disks or faces but can still retain the same offset but give bigger dish with different disks/faces. Front wheels have R disk, rear wheels have O disk. Both +10 offset and both 10 inches wide.
Look up the Work web site if you want to do some research.
https://www.sau.com.au/forums/topic/305615-r34-gtr-v-spec/#findComment-5060873
    • How much have you lowered?  I had 350Z springs in the rear and was able to pull the camber into factory spec with the factory arms on the rear, obviously the front ran negative camber as it isn't adjustable, but rotating the wheels regularly evened out the wear.
    • Either the installer needs to come back, you need an auto electrician, or you need to learn automotive electricals yourself.   First step Id look at is where that big thing came out of, is there still things unplugged at that location? Maybe they just forgot to put a relay in or something?
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
