When are you doing it? If it's Sunday I can come round and do it for you quickly if you want. I just have a long breaker bar which makes it easy and a modified harmonic balancer puller. Done it a hundred times.
  • Replies 1k
Posted Images
Yea, i'll start getting it ready on Saturday, I'll just remove the cover, cas, and accessory belts.
If it happens to spill over onto Sunday, then ill keep working on it, only thing holding me back is the 27mm socket. Got a mate with an impact wrench so that should make things a breeze (hopefully)
You know if the radiator needs to be removed?
I always remove the radiator due to my harmonic balancer puller. But it can be done with it in it.
Well I finish work at 4.30 on Saturday so if you still need it taken off give me a txt message.
And yes I'm still alive :P
You're all pretty queer.
been too lazy to deal with forums lately :/ and SLOWLY finishing this bloody motor off.
need to do some proper measuring to fit an oil cooler into the drivers guard LOL.
how are we all?
Who's friends with some one with an S14? Want to quickly test fit two products, a carbon roof spoiler and a carbon ABS cover.
Otherwise might just take them to work and wait for one to rock up in the car park lol
All good, got the flamin mongrel of a thing off. Its those damn stupid 6mm bolts that the rb uses.
Took a bit of muscle and patience but, at last.
New belt on and tensioned back up.
Job done.
Just need a new radiator now, the old 31 radiator had leaks in 2 places.
Not sure if the gtr one will fit Rob?
Hats off to Phil for keeping the diffuser I now own in such good condition for the duration he owned it. I straightened it out for I think the third time today. Have cracked quite a bit of the resin off it to :(
So if I keep going like this I might be up for a new one next year lol
Whats the latest on everyones cars in Townsville?
Edited by 89CAL
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
