since when? plenty of people have low mounted gt35s
and to all the stock ecu haters, it was running 7psi ffs, would have been running just as rich as it does with a standard turbo at 12-13psi. wont lean out until you start going past the max flow of the injectors or fuel pump.
OP: install your pfc, z32 afm and evc and get it tuned. see how it goes, then decide if the turbo is suitable and if you need bigger injectors
Hmm i didn't think you could fit a GT35 low mounted. Post up pics so we can see what size turbo it is.
Its got some numbers on it so i took a photo of those if they are any help...its got a 4" intake too, i only got told by a workshop when i took it in that they thought it was a gt35...but im not sure
Fair enough, i thought the size of a GT35 would foul on something low mounted. Havn't ever looked in to low mounting a GT35, all that i have seen have been high mounted.
Edited by PM-R33
blitz used kkk housings with turbonetics wheels, that k27 you have is a large frame one and no doubt of a mecedes truck or some random tractor
it is most certainly not a blitz turbo, nor is it a performace turbo.
2 secs and ill look up what it is off
ok just had a look...with out the proper build tags i cant see exactly what it is but it would have come from a Liebherr or deutz earth mover.
its a shame the tags have been removed other wise i could have given you a part number for a smaller turbine housing.
are there any tags or numbers on the turbine housing, it looks like a 13.21 rear housing (big)
Nope i just had another look and the only numbers on the turbo are of the ones i took the photo of... so if your saying this isnt a performance turbo...because arent the k27 a performance turbo? so is it still a k27 or....?
Im kind of wondering if i can sell this and wanting to see how much i should be wanting for it
Why would you? It would run like crap, laggy as hell and the stock ECU wouldn't know what is going on so it would run rich and pull timing. Not to mention you run the risk if something goes wrong and boost spikes to a proper amount for it that it can run efficiently (18+psi) you risk maxing out the injectors, maxing out the fuel pump, hitting airflow cut etc. Not saying it's going to kill something instantly but all in all its just not a good combination.
Obviously you can run it like that if you choose, hell you could run a T51R on the stock setup on 4psi, but is it going to be well setup and safe, no it is not. I ran my plenum and turbo upgrade on the stock ECU and it ran ok, did it run nicely and make power, no it did not and it's a fairly small turbo compared to a GT35, which the OP's number aint, it looks to be much larger atleast housing wise.
Edited by PM-R33
Kinda noob question here...
but i was wondering... would a decent tune with a decent ecu and uprated fuel pump, injectors etc make a gt35 less laggy or would it be un-noticeable? or not make a difference because of the size of it in the first place?
  • 9 months later...
Well....
I brought my r33 rb25det with this insanely big turbo already on the car....looks like a gt35 front but the exhaust housing of it is huge and when i would drive the car it would lag and in first gear kick in at about 6k revs, and 2nd like 5500, but when it kicked in it would sit me back in my seat on stock 7psi,
BUT i recently brought a new DSR 430 turbo, and then raised the boost up to 10psi, it spools up at about 3k and i get full boost by about 4-4500revs
But even though i raised the boost and its hitting boost for longer in the rev range....its actually going slower then the old turbo. The old big turbo i had i would be doing about 60 before changing into 2nd and about 100 at the end of 2nd, and it was on stock 7psi but with this dsr turbo i get to about 50kph in 1st and about 90 in 2nd gear... on 10psi
The DSR turbo keeps power through all the way to redline aswell,
So is this becuase the DSR430 turbo i brought a piece of chinese crap? or do i need a really decent tune? or a high quality turbo such as a garretgt30 or somthing?
Thanks guys!
hey bro i bought a dsr430 turbo and i had trouble installing it how did u install urs if u dnt mind me asking
    • Hi, wondering if the HKS bar and water reservoir still available? Thanks
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
