I've had my car for a few weeks now and I noticed that every now and then the revs will fluctuate when sitting at idle and usually when slowing down the revs dip really low and sometimes the car will stall.
I've done some research and found lots of information on faulty PCV causing the dipping revs but nothing relating it to the fluctuation.
I mentioned it to my mechanic and he said the car might just need a good run and may have picked up some bad fuel. Now 800kms later it still does it from time to time and it is driving me crazy.
The car is going to the mechanic on Tuesday to get the problem sorted and I wanted to give him an idea of what the problem could be. The car is a 1996 Skyline R33 GTS-T series 2 with 75,000kms on the clock.
Any help would be greatly appreciated.
Dylan.
https://www.sau.com.au/forums/topic/306256-fluctuating-and-dipping-rpm/
you might have already found this during your research, but a common problem for the idle issues is caused by a faulty/dirty AAC valve...there is also a DIY on how to clean it yourself.
I have similar idle issues but mine is ecu related due to an rb20 remap...
good luck!
Frankly, I don't understand what all the fuss is about erratic idle. It's only idle, FFS. If it were doing it in the middle of an overtaking acceleration, then, yes, you have a right to be concerned, but it's just at idle.
As for the stalling, service the AAC (will probably solve the disaster that is your erratic idle as well).
I have a similar issue with my car. It running a Haltech E11v2, Nismo 740cc Injectors, and when the aircon is on and i am slowing down to stop at the lights, it always stalls. Another thing it does is it rev hunts when idling at the lights sometimes (generally on warm days), but other times it can be fine.
What do you reckon? AAC Valve too?
does your AAC connected to your haltech? my friend here also uses haltech, but for AAC he says haltech needs additional controller to control AAC valve opening. Currently his aac valve isn't connected, and having same symptom like you. And also it stalls while parking (maneuvering/driving in slow speed).
Basic function of AAC valve is to increase RPM when there's additional load like aircon and power steering, otherwise it would stall.
Or just try to do simple fix by cleaning your AAC valve, works well on my rb20det, no more stalling issues
I'm fussed because it sounds annoying and can't be good for the fuel consumption, I want my car to be running top notch :D
Seems like everyone has a idling related problem.
Sorry for hijacking, I have a idling problem that seems to be related to surrounding temperature.
When I drive around during the day (outside temp is ~30+C) the base idling rpm is ~740 to 750, but when I drive around at night (outside temp would be low to mid 20C) the base idle rpm drops to around 680 to 700rpm?
At this dropped idle rpm you can feel a slight vibration from the steering wheel while stopped at the lights.
Any idea on why temperature is causing the drop in idle rpm? Still AAC valve related?
Car has basic mods. turbo back exhaust, POD, R34 GTT SMIC, bleed valve (up to 10psi), SAFC 2 & stock BOV.
Thanks.
Edited by Mayuri Krab
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
