evo all the way, + aren't wrx's meant to have alot of gearbox problems??? i've heard of heaps of people that have had to replace their gearbox....
yeh like who do you know?
this is what everyone says. even before i went to subaru this is all i ever heard.
but after owning a couple and being active on the rex forums for a long time, i rarely hear of people blowing their boxes EVER. i have heard of some of the earlier classics pre 00 doing their boxes. but these cars were used for hill climbs and motor sport. the old rexies have had 10 years of hard launching from various young males. this is to be expected.
extreme launching on startup time and time again will make any gearbox blow. whether it be ferrari, or evo or wrx.
go on the evo forums and find out how their 10 year old gearboxes are going after so many years of launching abuse. they all share the same fate.
like i said its user abuse over many many years and many many launches. not actually a design or manufacturing fault.
Like what was said it should be STI vs Evo in your decision, the WRX is more on par with the Galant VR-4 IMO. And go an Evo 5, 6 or 6.5 TME, all awesome cars and unlike the Impreza did not come from the Subaru school of ugly as f*ck cars.
i know a guy on his 3rd gearbox, but his is was the mid to late 90's version (the original shape) and he flogs the arse out of it.
also saying that the evo is more reliable than the wrx, well you would expect it to be as it costs a fair bit more, however other than the guy i know who goes through gearboxes, and another guy who blew the turbo while sitting flat to the floor along the highway seeing how fast it's top speed was, i haven't really heard that many more issues about it.
exactly
its a bullshiit myth that WRXs have weak/shiit gearboxes that break all the time. all user input. would happen to any car under the same abuse.
Edited by DrewII
What does your mate want to do with the car (mod wise)?
The wrx/sti is a nicer car for a daily but the evo is a lot more fun. In terms of mods; the 4g63 is a stronger engine than the ej20/25 (the 25 even less so).
As for the gearbox comments, the 5 speed is the one with the short fuse but that's only when you start running loads of power (200kw atw, remember stock they're about 130kw atw) and abuse the thing. Show it mechanical sympathy and it's okay. The 6 speed from the STI is the strong subie box. For the Evo's the 5 spd is the stronger box.
I own a wrx and have driven an 05 sti and evo 9 back to back. I preferred the Evo; the only reason I bought the wrx instead of the evo was because of cost (as I wanted it new).
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
    • You can set hard reserves on your battery system, and it can't be discharged past that.
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
