NISSAN GTR Posted February 2, 2010 Share Posted February 2, 2010 Mate of mine has a totally stock RB26 , R32 , just lately one of his ceramic turbos gave up at 70,000 kms, what is the best steel replacement turbo with a slight improvement in performance . thanks Link to comment https://www.sau.com.au/forums/topic/306559-ceramic-turbo-replacement/ Share on other sites More sharing options...
R31Nismoid Posted February 2, 2010 Share Posted February 2, 2010 Garrett -7's. Do a search, more information than you can poke a stick at. Link to comment https://www.sau.com.au/forums/topic/306559-ceramic-turbo-replacement/#findComment-5067554 Share on other sites More sharing options...
DVS JEZ Posted February 2, 2010 Share Posted February 2, 2010 hope fully no bits of turbine have gone into the engine. Link to comment https://www.sau.com.au/forums/topic/306559-ceramic-turbo-replacement/#findComment-5067592 Share on other sites More sharing options...
Buraz Posted February 2, 2010 Share Posted February 2, 2010 You can also look into putting steel wheels into your turbos, if its a tight budget and only looking at slight performance. I'm running 17psi on my ones and 287rwkw with supporting mods and it cost me $1100 with all the labour done myself, I bought the turbo cores of a member here with the wheels already balanced and ready to go and just added my exhaust housing and compressor housing of the old turbos. Not that hard if you have basic mechanical knowledge, I had no issues doing all this myself and saved alot on labour. But if budget allows, do what R31Nismoid recommended earlier Garrett -7, much better than my option and can make much more power as well as less work involved. Cheers Link to comment https://www.sau.com.au/forums/topic/306559-ceramic-turbo-replacement/#findComment-5067829 Share on other sites More sharing options...
MrStabby Posted February 3, 2010 Share Posted February 3, 2010 Aren't the -9's the way to go now instead of -7's? (or are they more expensive?) Link to comment https://www.sau.com.au/forums/topic/306559-ceramic-turbo-replacement/#findComment-5068779 Share on other sites More sharing options...
gtr fan Posted February 3, 2010 Share Posted February 3, 2010 (edited) Aren't the -9's the way to go now instead of -7's? (or are they more expensive?) Well Nismoids above post has thrown me as for the past few months I have noticed he is a pro -9 man Edited February 3, 2010 by gtr fan Link to comment https://www.sau.com.au/forums/topic/306559-ceramic-turbo-replacement/#findComment-5069007 Share on other sites More sharing options...
Brezza Posted February 3, 2010 Share Posted February 3, 2010 i can vouch for garretts being the best choice for a street replacement on a budget. i would say go the -7's or -9's i've got -5's which are a little bit of overkill, i only got them because they were the ones that came available the soonest when my stockers blew the rear wheel off. the -7's or -9's would be better for response and still have plenty of power! i hope your mates car will be fine after he gets the turbo's replaced and doesnt have my luck and have the motor blow a week and a half after the new turbos are installed. Link to comment https://www.sau.com.au/forums/topic/306559-ceramic-turbo-replacement/#findComment-5069040 Share on other sites More sharing options...
R31Nismoid Posted February 3, 2010 Share Posted February 3, 2010 Aren't the -9's the way to go now instead of -7's? (or are they more expensive?) His post says slight improvement over factory, -7's are the closest. -9's are 330rwkw, which IMO i wouldn't be taking a R32 motor to that level given their age/conditoon now. So 280rwkw or so on -7's would be reasonable and about 30-40rwkw more than factory turbo's. If he wanted a bit more performance, with a planned rebuild, then -9's for sure. Link to comment https://www.sau.com.au/forums/topic/306559-ceramic-turbo-replacement/#findComment-5069052 Share on other sites More sharing options...
MrStabby Posted February 3, 2010 Share Posted February 3, 2010 Say you were running 300kw, would the -9s produce that with a slightly lower temperature (due to the better compressor efficiency) than the -7s? Or are they only better when you're running them right at the peak? Link to comment https://www.sau.com.au/forums/topic/306559-ceramic-turbo-replacement/#findComment-5069069 Share on other sites More sharing options...
(OO)SKYLINE(OO) Posted February 3, 2010 Share Posted February 3, 2010 Rebuild it with steel internals or go for R34 GTR N1 turbo's. Or any aftermarket that is listed in thread. Link to comment https://www.sau.com.au/forums/topic/306559-ceramic-turbo-replacement/#findComment-5069083 Share on other sites More sharing options...
R31Nismoid Posted February 3, 2010 Share Posted February 3, 2010 Not 100% sure but it's not going to be a 30 degree difference or anything major i would imagine. Probably a difference, however majorly signifigant? Probably not. 300rwkw i would still pick -9's though. 280rwkw would be the aim for -7's. Link to comment https://www.sau.com.au/forums/topic/306559-ceramic-turbo-replacement/#findComment-5069088 Share on other sites More sharing options...
Bunta Posted February 3, 2010 Share Posted February 3, 2010 just a slightly off topic question....why are the power out puts between a -7 and a -9 so different, looking at the spec sheets they are so close to the same it isnt funny (-9 slightly smaller in the compressor and slightly larger in the turbine but we are talking 0.0Xmm difference) Link to comment https://www.sau.com.au/forums/topic/306559-ceramic-turbo-replacement/#findComment-5069126 Share on other sites More sharing options...
NISSAN GTR Posted February 3, 2010 Author Share Posted February 3, 2010 Rebuild it with steel internals or go for R34 GTR N1 turbo's.Or any aftermarket that is listed in thread. what is the benefit of N1 turbos , everybody says there great , what would a pair set me back! Link to comment https://www.sau.com.au/forums/topic/306559-ceramic-turbo-replacement/#findComment-5069196 Share on other sites More sharing options...
(OO)SKYLINE(OO) Posted February 3, 2010 Share Posted February 3, 2010 what is the benefit of N1 turbos , everybody says there great , what would a pair set me back! They came from factory on the R34 GTR V-Spec II N1, R34 GTR V-Spec II Nur and R34 GTR M-Spec Nur. R34 GTR N1 turbos came from factory with steel internals and they ran 1.2 bar boost stock. So they are very strong and responsive. I had driven a R34 GTR V-Spec II Nur with 306 rw kW's still retaining the N1 turbos. Was excellent. Try the for sale section and from memory about $1450 + a pair. - http://www.skylinesaustralia.com/forums/Wr...mp;hl=n1+turbos <--- He's selling them for $1450 a pair. Should be straight bolt on fit too. Link to comment https://www.sau.com.au/forums/topic/306559-ceramic-turbo-replacement/#findComment-5069278 Share on other sites More sharing options...
Buraz Posted February 3, 2010 Share Posted February 3, 2010 They came from factory on the R34 GTR V-Spec II N1, R34 GTR V-Spec II Nur and R34 GTR M-Spec Nur.R34 GTR N1 turbos came from factory with steel internals and they ran 1.2 bar boost stock. So they are very strong and responsive. I had driven a R34 GTR V-Spec II Nur with 306 rw kW's still retaining the N1 turbos. Was excellent. Try the for sale section and from memory about $1450 + a pair. - http://www.skylinesaustralia.com/forums/Wr...mp;hl=n1+turbos <--- He's selling them for $1450 a pair. After reading a few topics and the GCG website the gt2860r-7 are equalent or closest to n1 turbos that came in the cars that you mentioned. My understanding is that the gt2860r-9 are equalent or closest to HKS GTSS. Link to comment https://www.sau.com.au/forums/topic/306559-ceramic-turbo-replacement/#findComment-5069404 Share on other sites More sharing options...
bradsm87 Posted February 3, 2010 Share Posted February 3, 2010 just a slightly off topic question....why are the power out puts between a -7 and a -9 so different, looking at the spec sheets they are so close to the same it isnt funny (-9 slightly smaller in the compressor and slightly larger in the turbine but we are talking 0.0Xmm difference) The physical dimensions of the wheels are one of MANY variables. The -9's have newer more modern wheels which flow more and more efficiently without needing to be bigger or lighter. To the previous posts about the -7 turbos, I'll say it again, -9's AREN'T any laggier than -7's so there is NO advantage of -7's! If u only want to make a certain amount of power, just run -9's on low boost! Link to comment https://www.sau.com.au/forums/topic/306559-ceramic-turbo-replacement/#findComment-5069424 Share on other sites More sharing options...
NISSAN GTR Posted February 3, 2010 Author Share Posted February 3, 2010 i can vouch for garretts being the best choice for a street replacement on a budget.i would say go the -7's or -9's i've got -5's which are a little bit of overkill, i only got them because they were the ones that came available the soonest when my stockers blew the rear wheel off. the -7's or -9's would be better for response and still have plenty of power! i hope your mates car will be fine after he gets the turbo's replaced and doesnt have my luck and have the motor blow a week and a half after the new turbos are installed. Damn that is bad luck Im guessing the ceramic turbos did the damage initially. I was thinking the way to go is gt2860r-7 Are bigger turbs generally more laggy. Everyones advice has been extremely helpful . Link to comment https://www.sau.com.au/forums/topic/306559-ceramic-turbo-replacement/#findComment-5069762 Share on other sites More sharing options...
R32 Zilla Posted February 3, 2010 Share Posted February 3, 2010 I have R34 N1's for sale. Same as -7's. Selling for $1500ono. Pm me for details or look in the for sale section. Tim. Link to comment https://www.sau.com.au/forums/topic/306559-ceramic-turbo-replacement/#findComment-5069775 Share on other sites More sharing options...
bradsm87 Posted February 3, 2010 Share Posted February 3, 2010 Damn that is bad luck Im guessing the ceramic turbos did the damage initially. I was thinking the way to go is gt2860r-7 Are bigger turbs generally more laggy. Everyones advice has been extremely helpful . why not -9's? Newer more modern turbo. Same response, more efficient, more power, same price. I dunno why they don't discontinue -7's and put an end to all this confusion. Link to comment https://www.sau.com.au/forums/topic/306559-ceramic-turbo-replacement/#findComment-5069801 Share on other sites More sharing options...
(OO)SKYLINE(OO) Posted February 4, 2010 Share Posted February 4, 2010 After reading a few topics and the GCG website the gt2860r-7 are equalent or closest to n1 turbos that came in the cars that you mentioned.My understanding is that the gt2860r-9 are equalent or closest to HKS GTSS. Yeah, I think your right, by looking at my Turbo Chart, the specs seem the same. And yes the -9's = HKS GT-SS (well, very close) Link to comment https://www.sau.com.au/forums/topic/306559-ceramic-turbo-replacement/#findComment-5070581 Share on other sites More sharing options...
