I didn't think my 180 had enough panel damage so put it into the wall for everyone's enjoyment :cool:
will fix it when I cbf and do more skids, only real damage is rad and cooler core (apart from panel work) so shouldn't be much to get it back to it's former glory :D
I had a geat time last night there where about 10 first timers out there. I hit the tyre wall at the end of the long left turn around the end of the grand stand. Ill be up for a front spoiler and nothing a bit of cut and polish wont fix. I will take some photos soon. I guess you wont want to go tandem then next time hey krishy!
OH SNAP! I just connected the dots - Andrew that was me that was talking to tuffy and I was looking at your car in the garage.
Unlucky to hear about the car man, how did you get her home?
drove (limped) it to the pub in mallala, the reactions from the locals was f**king funny, rolling up in some smashed 180 with the thing barely idling with shit draggin on the ground :P
got it towed to my aunt's then towed it home myself with a mates car just before. ghetto repairs to commence soonish
Edited by AndrewJZX100
Pics?
I seen you sitting in the car park man, I would have some how helped if I could have but nothing I could have done.
Next skids are in Aug I think, unless someone organizes a private day
Here is a photo from saturday night I wish the tyres had of been the white ones that I hit. Now I know how to tint your headlight just ram a wall of tyres. Leaves a nice black smudge across the lens.
more then happy to try and learn mate.....hopefully will have the 2way in there soon enough.....and then we can go tandems lol kamikaze style
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
