just did my gearbox oil change today and heck, might as well take a couple of pictures in case some of you guys are wondering how its being done.
before i continue, you have to bear in mind that ANY oil change can be a VERY dirty, messy and tiring job but think of the satisfaction and money saved. THat's what motivated me in the first place. I also felt that it would help me understand my car better :sly:
anyway... here goes... my FIRST gearbox oil change in my R32
I needed to get the car high up from the ground so that I will have plenty of room to move around. I thought of car jacks and found these steel ramps at cash converter for only $20!! Each of them holds a maximum weight of 850kg. It holds the car pretty high up off the ground and its great for future use in engine, diff oil change and brake flushing/bleeding as well as some underbody works.
PLEASE do remember to (1) handbrake, (2) get the car in gear and (3) chock the rear wheels of the car.
Recommended equipment:
Get a LONG wrench for that ALL-SO-IMPORTANT leverage(size 1/2 inch)
Get a pump and your new gearbox oil ready.
tools, torchlight, degreaser, rags, hose, vacuum cleaner :)
and NOW, the fun part begins....
when you are done with your warmups and body flexings... get under the car to the gearbox. There is a drain plug on the bottom centre of the gearbox, there is no way you can miss it.
It is IMPERATIVE that you undo the filler plug FIRST before the drain plug!! If you undo the drain plug first and got all the oil out and then realized that the filler plug is stuck... you can start building a display cabinet for your car :tool:
The drain plug is usually the harder of the 2 to undo... i had a bitch of a time trying to get it out... broke 1 wrench and decided to get the STRONGEST and THICKEST 1/2inch wrench i can find in Repco... the longer the leverage, the easier it is to undo the plug. Another recommendation i had was to undo both plugs just after a drive so that all compartments are still hot... but the downside of this is that you will have to be EXTREMELY careful of the cat, exhaust piping and the gearbox itself becos it will get freaking hot.
make sure you have at least a 5litres and above oil tray for the old oil once the plugs are undone.
when the old oil is draining from the gearbox, get to work on the 2 plugs.
https://www.sau.com.au/forums/topic/30665-r32-changing-gearbox-oil/
Clean them both, esp the drain plug. You might noticed some metal shavings from the magnetic part of the plug, get them off... its normal wear-and-tear from the gearbox. Run a single layer of plumbing tape around the threaded end of the plug (not necessarily but i did it anyway...
once all the old oil is drained, put the drain plug back. How tight you want it is ALL dependable on yourself... gearbox oil can last for a pretty long time and its usually recommended that you get it changed once every 2 years (dun quote me on that). If you screw it tightly with a vengence, then you will probably end up cursing yourself more then... anyway, i tighten it with a vengence... :)
the rest of the work is pretty straightforward... pump in the new oil (filler hole) till it starts overflowing from the filler hole. once that's done, screw the filler plug back on... again with a vengence.
and wala... you got new gearbox oil...
btw, i recommend that you get your driver seat covered like i did... once any stray oil gets onto the seats, the stain and smell stays on...
next project for me is diff oil change... wanted to do it today as well but going to read up more on the redline oil specs first...
hope this helps
cheers
glenn
if you are sliding under the car with your head towards the back of the car.. the filler plug will be on the left side of the gear. If you can find the drain plug, run your left hand (careful when hot) along the gearbox and you will find the squarish filler plug. It sticks out like a sore thumb and there's no way you can miss it.
ask for the redlineoil .. chk out www.redlineoil.com.au for the nearest retail outlet near you.
run a search thru this forum and you will find more info on it.
tranmission filter? that i am not so sure and dun wanna give you bogus advice. run a search and see what you can find. there's no filter on a manual, only a tiny magnet on the drain plug to attract all the stray metal shavings.
  • 1 year later...
i prefer to use the Motul range of oils...
they just released their LSD oil in 1L containers!! :D (instead of 10L drums)
Also can anybody confirm this:
gearbox in rb20 takes 2L, diff takes 1L??
engine - 300V Chrono (10w40 100% synthetic ester)
gearbox - Gear 300 (75w90 100% synthetic)
diff - Gear FF Competition
brakes - RBF600 (DOT4/600, 312 degree boiling point!)
  • 5 months later...
  • 2 months later...
  • 1 year later...
    • I don't know if you can disassemble the thing and put it backwards for different ramp rates. They're both "2 ways" or both "1.5 ways" because well, 2 ways and 1.5 ways are the same 'thing' I do not know for sure, but I believe the 38420-RSS15-B5 is the 1 way, and 38420-RSS20-B5 is the two way. In other words, I predict Nissan considers this: to be a 1.5 way. No idea what actually happens when it arrives/you disassemble it. It would be an excellent question to ask Nismo directly! I somehow doubt you will get an answer though, I feel you would be the first person to document what you encounter when you open the box and the internet would be grateful.
    • I'm going to slap an old nismo logo sticker on my spare one and sell it to the land of the free for a thousand bucks
    • lol, probably should have read further!
    • Well - they have arrived.  And they are easy on the eye to put it mildly... These only have three bolts - but for a start there is a key that fits with vacuum like precision..  And as you can see by my ruler, the interface is large..   I listened to a podcast on HP Academy about Dan (KiwiCNC) and I'm more than comfortable he knows what he is doing. R35 Bearing assembly should arrive later today so can mock that up for a look. Can't wait to get these on and get some brake pressure logging too. IMG_3860.MP4
    • I would be very confident that they are the same parts (the 2 different SKUs). It seems very clear that you can drop the cam in the 2-way opening, or in the other opening. If you arrange it in the other opening in the same way that you see any other 1-way diff, ie, with the flat of the cam up against the 1° side of the opening, then it would work as a 1-way. It can only spread the ramps when driving forwards - cannot spread the ramps on overrun. It would then appear obvious that if you put the cam into the opening "backwards", that you would get the angled flats of the cam working onto the "points" of the 1° side of the opening, which would give you ramp spread in both loading directions. I do wonder if the forward direction of the 1.5-way config is equivalent to the forward direction of the 2-way, seeing as the cams are flipped and the angled surfaces on those would need to be the same on each side - AND - clearly when installed in either the 2-way or 1-1ay configuration they are not intended to work exactly the same (the ramp angles on the 2-way are 10° different between forward and backward, and the ramp doesn't exist in the 1-way config). 'twere me, I think I would rather actually have a set of rings that offered the 2-way with two different sets of ramp angles, say the 55/45 of the existing design and maybe a 45/37.5 combo for a less aggressive effect), AND another set of rings with a dedicated 1.5-way opening and a dedicated 1-way opening. The 1.5-way opening would actually have the steeper angle on the overdrive side that causes it to be less pushy than the forward drive angle, like you see in many other diffs. But really - if this Nismo thing is thought out properly and all those surfaces work on each other the way that they need to, who am I to argue?
