Yeh it is quite tight. Gonna have to pull some magical fab or machine work out of my arse to get it together nicely.
I was hoping to get the wastegate part all welded tonight, but we spent all night trying to find a stupid miss with the race car. It seems like an injector or maybe two are not playing the game!
In regards to the 4" dump pipe, pretty much as TiTAN said. Im attempting to cheat, but utilising 4" to dissipate enough heat so by the time exhaust gas reaches the 3" its not choke up.
Dude you are on the ball!
Yeh 2.5" it is!
Well since im only running low boost out of it, it needs to pass alot of gas. I need the wastegate to control boost perfectly and without any silly issues from undersize piping or improper placement.
Took the better part of the day but I got the turbz outlet to charger inlet done! Thank god that part is over, it was quite daunting thinking I wasnt going to be able to fit it together.
Tomorrow will be the 4" turbo intake and hopefully start the catch can (lol which I forgot about) and then I think thats the twincharge fab work done!
Still left with engine stuff to do, hooking up the power steering and water/methanol injection kit!
Cheers Chris.
That pipe actually has a 3mm wall lol. So its not so bad. The donut sections are more like 1.2mm I think. But I just focus the arc below the joining points and once the heat gets into the thicker parent metal I just move the arc towards the join when feeding the filler and it just melts up onto the pipe nicely. The donut onto the compressor cover was more difficult. That cast just doesnt like melting nicely.
Awesome build so far, totally enjoying the thread and learning lots too. You must have the patience of a saint to get this far and not be able to drive it =) Looking forward to checking back for updates and seeing the finished product. Congrats so far and good luck with the rest!
Thanks mate! I am itching pretty hard to finish this thing so I can drive it.
I got about half way through the breather can tonight.
Its basically going to be a mini dry sump tank, with 4 lines going in, one from each rocker cover and two from the crankcase, and then one line (from the pipe tee'd off the middle one at the bottom) down to a one way valve and into the exhaust just after the 4"-3" reducer. I'll have a pipe cut with a 45 deg end sticking into the exhaust at 45 degrees and flush with the centre line so I can take advantage of the fastest flowing gas(centre of the tube - Poiseulle flow) moving past it, generating the maximum amount of vacuum through the attached line. I believe Bernoulli's principle has something to do with how this setup works.
Hopefully it works well. This setup has been around for quite a long time apparently, but ive never seen anyone take advantage of it, atleast not around these forums. The old fellas who schooled me about it said he was doing it to race cars back in the 70's and 80's, I guess dry sump setups and vacuum pumps took over afterwards.
they didnt have catalytic converters back then though either - any chance of issues with unburnt oil gumming up the cells?
p.s. love the effort you're putting into this - gotta love being able to make shit for yourself
lol...what cat?
But yes, if you were running a cat, then you would put it after that point.
You are not wrong Chris. It is cool, though Ive never known any different. Everyone in our family has been of the do it yourself mindset. But the same old guy who told me about the exhaust evac setup also said if you have an inquiring mind you can pretty well do anything. This guy was a chippie by trade, but spent 30+ years of his life as a race car builder!
wanting and having the means to do are different things though unfortunately.
re: oil/air separator - at what temps does oil burn? there must be a point along the exhaust where the oil vapour would not turn to ash and simply burn off and carbonate at a later stage under longer periods of load (ie track day)
are you running a catch can along with the separator? im guessing not since you have no more room left lol - just thinking in terms of a cat bearing road car.
oooh ohh another thing, exhaust backpressure if it occurs will cause your dipstick to mimic a bullet once crankcase pressure builds up - it is easy enough to test the back pressure but its probably something you'll need to ensure there is none throughout the rev range at the point you input the breather tube
though im sure you already knew this lol
I suppose having the means makes it easier doesnt it.
Depends on oil, but probably a couple hundred degrees. I think the flash point is the proper term. I guess that is possible, if the exhaust was so hot it would just vaporise the oil vapour. But how is that any different to oil bypassing rings, turbo bypassing oil and burning, or dodgy valve stem seals letting oil into the chamber? Essentially the samething is happening except alot worse. I think if its setup right there shouldnt really be much oil burning in the exhaust, im hoping it will mainly be air! Lol but my can may not be upto scratch and I might find a shit load of blue smoke billowing out the exhaust.
That breather can is my catch can and seperator. The way im hoping it works is the oil will settle at the bottom and the air will rise to the top and get sucked out the opening at the top of the middle tube, go back down and out the tee'd in bit at the bottom and go out to the exhaust via the one way valve. So if it works properly then hopefully the air wont be carrying as much oil as usual. That is the plan anyway.
I will be putting a drain bung on the bottom and a capped off dash 12 weldon on the roof incase it needs a filter or something if there is a problem.
Yeh thats going to be the tricky bit, as im going to take a stab at where to put it, rather then testing the exhaust system first. However if there is sufficient back pressure then im sure ill have power making problems as well as that issue, but as the easy fix I can just put a filter on the -12 on the lid as a temporary fix until its sorted properly.
lol or just go and buy a stupid vacuum pump and get 20+ inHg of vacuum through the motor! But that would be too easy.
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
