Hey guys,
Anyone up for a drive tonight on the nrth shore?
maybe head down to the beaches for some chickens plus.
I havent been for a cruise in over a year and a half and its been long enough, If anyone is keen please let me know.
Mike
https://www.sau.com.au/forums/topic/306962-drive-tonight/
Im keen, but its raining.
Even more reason to go for a drive!
I would be keen as for the drive, as i live at Newport, but got my missuses 21st party tonight. :blink:
Let me know next time for sure though. I'll bring the boat along.
https://www.sau.com.au/forums/topic/306962-drive-tonight/#findComment-5074174
To all of those who didnt wanna come out due to wet roads.......THEY'RE DRY NOW! lol
Im still looking to head out for a drive tonight, let me know if keen, other wise ill just scrap the whole idea.
https://www.sau.com.au/forums/topic/306962-drive-tonight/#findComment-5077107
If your still keen for a northern beaches drive, what about tomorrow night (10/02/10)?
I mentioned it to a couple of mates and they were keen, so there would be at least 3 of us (R32, R33 and R34 :D) coming to meet up.
How about meeting at St Ives where you suggested, then doing Akuna / McCarrs creek and then down to somewhere for food?
https://www.sau.com.au/forums/topic/306962-drive-tonight/#findComment-5078617
I mentioned it to a couple of mates and they were keen, so there would be at least 3 of us (R32, R33 and R34 :() coming to meet up.
Or Gen4 :banana:
https://www.sau.com.au/forums/topic/306962-drive-tonight/#findComment-5078898
I mentioned it to a couple of mates and they were keen, so there would be at least 3 of us (R32, R33 and R34 :( ) coming to meet up.
Sounds good, what time shall we meet?
https://www.sau.com.au/forums/topic/306962-drive-tonight/#findComment-5079108
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
