  • Replies 49
Was a good event!! only one Nissan Gtr there however.. and only 1 or 2 other skylines..
loads of Porsche's which was actually pretty good to watch.. pity you guys didn't bring up the 35's would have loved to see them. and for 700 bucks for over 2 hours of track time Bathurst doesn't come cheaper! or does it?
sounds like the event went well, kind of sorry i pulled out. lack of meaningful communication by the organisers only three weeks out didnt help. Glad it all went ok. I suppose it doesnt come cheaper than that, perhaps on a price per lap, drive bathurst may be cheaper, but much higher entry cost overall.
Was good to catch up with you Andrew!!
What a Fantastic event...I got to check out the Control Tower and even got a Hot Laps with Warren Weldon in the Lexus V8 Safety Car...was awesome!
For the money spent was well worth it... Was just over 800entries...wow! :D
That GT1 was worth $5Million
The Martini Porshce was worth $3Million
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
