hey i was wondering if you able to import a car yourself and how much it will cost extra for compliance etc etc
they have s15's for like 7 grand over there so if thats correct how much extra will i be payin to get it here and everything else.
https://www.sau.com.au/forums/topic/307350-importing-japan-cars/
buying an S15 for about $7K will cost around $18K landed complied and rego'd. just remember you can only import 1999 model Spec Rs, and early 2000 models (most people just play it safe and stick to 1999 models).
if you are after a really clean S15 I have one at the moment. I imported it around 18 months ago. I bought it at auction in Kyushu japan and bought it to aus for my flat mate. He's now moving overseas and didn't have time to do anything about it so being the nice guy I am I bought it off him. It's white and completely stock apart from an Apexi pod filter (still have stock airbox).
$7000? thats around 540,000yen at the current exchange rate. Thats a little too cheap.
I think you need to pay double that for a half decent car. The brokers can correct me if I'm wrong.
Don't forget you also need to pay import duty and gst.
It would be best to talk to one of the friendly importers that frequent this thread, they'll give you a realistic price.
extra 11 on top? really shippin fee was like 2 grand on this site and complied i rang up said 3 grand and rego 1 g....
ok, so $7K for the car (which will be pretty poor at that price, good ones are closer to 1M than they are to 500K)
90,000-150,000yen FOB
$2K in freight
$300 in clearance, customs entry, AQIS attendance etc
$200 in cleaning
5% duty
10% GST (includes car cost, FOB, freight, the whole shebang)
$200 in towing
$3K in compliance
$1K in rego
ok, well that's about $9500 so call it $10K to be safe. which is about right. Basically if you bought a car at auction in japan for $10 it would still cost you nearly $10K by the time it's complied, registered and on the road in aus. yeah that estimate is a bit conservative but most guys doing a one off import will encounter some un-expected costs somewhere along the line. maybe a new set of tyres adds $1,000, or it needs a small guard repair due to damage in transit. shit like that.
plus the fact is a Spec R S15 for 500,000JPY is going to be fairly average.
anyway, it's entirely up to you.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
