not 100% correct, its hard to find good staino welders in the retail industry.
Try Proserve in Malaga if the work you want done needs to be PRETTY. my work uses them when we need tanks fabbed and they need to look like perfection. on a side note you will end up paying for the quality too.
regards
Chris
I would say welding Titanium is similar to welding aluminium/steel than Stainless. Stainless is a poor conductor of heat, whereas Ti is reasonably good.
Typically everyone uses TIG for stainless, but it depends on the application. Personally I use TIG for welding exhaust systems, but it requires tight tolerances on your joins.
Anyone that can weld with a TIG should be able to have a crack on Ti. What exactly are you welding? If it's an exhaust system or lobster style intercooler pipes, make sure you get the suitable grade of Ti.
I will go out on a limb and say NOBODY uses MIG for Titanium. I've never seen titanium wire to feed through a MIG. :D
It largely depends on what you can get.
In Melbourne I couldn't find anything. From memory a company called Austral Wright metals used to have something, but I don't think they do any more. Most of the time you have to import it.
Good luck in finding a dealer. I've lost all my contacts :(
Perhaps try ebay:
stores.shop.ebay.com.au › eBay Stores › TITANIUM JOE
or similar...
Grade 5 (Ti6Al4V) is one good grade, but pretty expensive.
Grade 18 (Ti3Al2.5V) is a good one for exhausts as it has palladium alloyed into the titanium alloy which increases corrosion resistance. But we really are splitting hairs. The best corrosion resistance is stainless though. But can't compete with the lightness of Ti.
Basically as I said before, any titanium alloy is good as long as you can get it as they all share very good corrosion resistance with a light weight.
Unfortunately trying to find someone who can mandrel bend Titanium is non existent. That's why everyone has to do lobster cut/welds. I did ask alloy bull bar manufacturers, but they said they wouldn't look at it due to the strength of Ti compared to Al, even if it was annealed!
Another alloy which is excellent for exhaust headers (ie extractors) particularly for turbo applications is the super alloy "InConel". Now this is better than titanium as it has a higher heat resistance, and therefore is harder to weld. It's used exclusively for super cars and formula 1 and other high end race applications where the engineers have an unlimited budget. But you'd have to buy a couple of tonnes (or something like that), and auction off one of your kidneys at the same time for the funds. I'd only use that for headers though. Not full exhaust systems.
Inconel for headers and dumps im guessing. Titanium starts oxidising at around 500 degrees.
I had a quick ring around and you are right, they all want to import it from the states, 2 to 3 weeks and if you need a price, you cant afford it.
  • Like 1
Another way of making tube to your specifications is to roll a sheet into a tube. It only works for narrow sections (as rolling long tubes is a pain), but you can use a rolling machine similar to what the panel beaters use.
I did find that getting 3" tube or 2.5" tube in titanium is a pain. Getting sheet is easy, and all you do is cut the sections you require, roll them into diameter, and weld the ends, then weld the sections together to get your required lobster design. LOTS OF WORK... :(
Not a bad idea, if it was thin sheet it would roll fairly easily. You could make your own mufflers the same way, don't imagine a Ti muffler would be cheap.
Anyone know how it welds? Easy to blow holes in thin sheet?
<br />It largely depends on what you can get.<br />In Melbourne I couldn't find anything. From memory a company called Austral Wright metals used to have something, but I don't think they do any more. Most of the time you have to import it.<br />Good luck in finding a dealer. I've lost all my contacts <img src="http://www.skylinesaustralia.com/forums/style_emoticons/default/sad.gif" style="vertical-align:middle" emoid=":cool:" border="0" alt="sad.gif" /><br />Perhaps try ebay:<br />stores.shop.ebay.com.au › eBay Stores › TITANIUM JOE <br />or similar...<br /><br />Grade 5 (Ti6Al4V) is one good grade, but pretty expensive.<br />Grade 18 (Ti3Al2.5V) is a good one for exhausts as it has palladium alloyed into the titanium alloy which increases corrosion resistance. But we really are splitting hairs. The best corrosion resistance is stainless though. But can't compete with the lightness of Ti.<br />Basically as I said before, any titanium alloy is good as long as you can get it as they all share very good corrosion resistance with a light weight.<br /><br />Unfortunately trying to find someone who can mandrel bend Titanium is non existent. That's why everyone has to do lobster cut/welds. I did ask alloy bull bar manufacturers, but they said they wouldn't look at it due to the strength of Ti compared to Al, even if it was annealed!<br /><br />Another alloy which is excellent for exhaust headers (ie extractors) particularly for turbo applications is the super alloy "InConel". Now this is better than titanium as it has a higher heat resistance, and therefore is harder to weld. It's used exclusively for super cars and formula 1 and other high end race applications where the engineers have an unlimited budget. But you'd have to buy a couple of tonnes (or something like that), and auction off one of your kidneys at the same time for the funds. I'd only use that for headers though. Not full exhaust systems.<br />
<br /><br /><br />
InConel is not used in supercars as it's classed as exotic materail and is illegal, the best you get in supercars(V8) is 321 grade stainless. And to weld InComel properly you meed a atmostphere of inert gas i.e argon/helium mix is the best I've used to help with the heat normally a 30% mix
HAha... Misunderstanding!
I'm pretty sure the McLaren F1 supercar uses inconel. I'm also fairly certain that Porsche used inconel on some of their more exotic cars such as the Carrera GT. Mercedes also used inconel on their SLR. Not sure about Ferrari's Enzo.. etc. etc. I'm not sure what super cars you are referring to? If you are referring to the current breed of V8 "supercar" dinosaurs, I'll take your word for it, but I don't really classify them as "super cars"....
  • 4 months later...
Trying to find someone who does Ti welding in Perth, its for an exhaust.
Cheers
Rob
Rob ring L&Fpreformance in welshpool,
Brad Stacy is the welder there & i think they can weld it,ok ,
Depends on the application. Typically the usual Argon gas specified for TIG welding is a good enough 'shield' to stop oxidation of the weld when molten. So you just weld the stuff as per usual with the TIG. (making sure you have the right gas in the bottle!)
If you are welding pressure vessel tubing or similar, purging the tube with Argon helps minimise oxidation/porosity when you penetrate through to the other side. It's all fairly straight forward.
For example, if I was welding a Ti tube with a Ti fitting on the end, I would run the torch gas (without welding) into the tube that was taped up on the other end. I'd fill the tube with argon from the torch allowing the oxygen to escape from the other side. Once I think most of the tube is full, I tape up the two holes (one at one end where you put the argon and one at the other which allows the purging to take place, I then start welding.
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
