the 1.3x rule applies to tyre width, not wheel size.
there are not rules as far as rim diameter goes, provided that the outside diamater isn't more than 15mm smaller or larger than the standard diameter of the wheel and tyre, and the tyres must have the same load rating (or higher)
also that link to the NSW RTA states that you can only go a rim 26mm wider than the widest rim on the tyre placard without needing to get it signed off on by a signatory. and the widest you can go is only 2" wider. so that means you could only go a 8.5" wide rim on a 33 gts-t, etc.
qld however only uses the 1.3x rule for tyres (plus load ratings) and the +15mm diamter rule. no rim width rule.
seriously who gets defected for rims these days? the last time ive ever heard of sum1 being defected for rims was probly 4-5 years ago. police are more concered bout engine mods and epa guidlines than the size of your wheels.
im from NSW... i just wanna know the maximum legal rim size for r33 gtst cuz i dont wanna get a yellow haha
Wheel cannot be more than 26mm wider than the widest on the tyre placard. Offset cannot be greater than 12mm lower than the lowest offset for any wheel on the tyre placard. Wheels cannot be narrower than the narrowest wheel on the placard. Offset cannot be higher than the highest stock offset.
Tyre diameter cannot be more than 15mm outside the diameter of the stock tyre (greater or less than). N.B. the wheel diameter is "free" as long as you can find a tyre that fits within this bound, regardless of what a cop tells you.
However, since you want to avoid a yellow, a lot of cops mistakenly believe that you can only go up 2" in diameter so for safety's sake I'd recommend that.
It's all on the RTA web site, as [200] said.
QLD Standard : The rim diameter may be varied from the standard size but the overall diameter of the tyre must not vary by more than +15mm or -26mm.
straight off pg 11
http://www.transport.qld.gov.au/resources/...r_vehicles2.pdf
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
