Live streaming here, its pretty good!
http://www.ustream.tv/channel/bathurst-12-hour
Also natsoft has results here, updated every few minutes
http://www.natsoft.com.au/cgi-bin/results....2/2010.MOUN.R14
as usual in prod car racing these days, there are evos everywhere.
https://www.sau.com.au/forums/topic/308140-bathurst-12-hours-on-today/
I hate seeing that sort of thing - what the hell was herridge doing? yellow flags everywhere and he still drives into the rear of a stranded car at full pace.
people have to take yellow flags seriously, they are not a chance to catch up they are a safety warning
yes....but only because officals don't enforce the rules and because drivers and teams choose to ignore safety.
they are spot on about bringing back double waved (saying where the major incident is) but that doesn't take away the driver's ultimate responsibility for safety.
lol too slow duncan...they've been leading all day but got taken just before the yellow flags apparently :)
too true. how interesting is this though. as usual the mountain throws up all sorts of shenanigans.
It was a massive weekend I can tell you!! Was up there helping improved production category and car 24 walden motorsports..we unfortunately didnt finish due to mechanical issues :devil: so upsetting as we were doing so well up to lap 68!!!
Its a fantastic event and well worth coming up for a looksee.
Well done to all that competed the conditions were incrediable :) it all happens at bathurst
well what a day!! 1 out of 2 of our utes finnished.
the ve holden ute got 7 hours in and broke a timing chain again!! this time a double row rollmaster!!
the falcon (grove) went thru for a finnish and class win. class g, crossed the line with one tyre blown out and running on the rim lol.
got held in scrutineering till 10pm. lots of cars got busted.
namly the easts evo. was caught with differant compound front and rear tyres. woops!
also im pretty sure the walden ve got pinned for the same thing after qualifing..
so pro-duct will finnish second now! holt bmw got held in scrutineering for a while too. not sure if anything was detected.
used only half of the brake pads. and finnished on the tyres we stated. still with 3mm left on them. apart fron two puntures on thre front right..
i look forward to doing it again!! mayby the holden will get a third time lucky..
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
