ok its nothing big (well i hope not)
whenever i start my car (cold start in the morning or if the car has not moved for a few hours or so) i always see as i start the car the oil pressure gauge kicks in and reads high as the engine is cold and the pressure is high bla bla bla all is normal and it drops as the car warms up. but a month ago i took off my rocker covers and plenum to get it cleaned and painted so when removing this allot of vacuum hoses had to be disconnected.
while everything was out my cams were visible so just to prevent anything from getting in there i covered all opening and the top of the motor with a sheet. after all the painting was done i connected all my hoses back and made sure i didn’t leave anything behind or any nipples without a hose. all is well. but ever since then when i start my car up, it now takes a little longer then normal for the oil pressure to build up. so when i start my car (if it hasnt moved for a while) ill get a little bit of a knocking sound like tappets with no oil around them and then my oil pressure gauge kicks in to the normal high read and the noise stops (all this happens within a second maybe less but its noticeable).
i have checked for any cracked hoses or lose connection or to see if i left anything off and i cant find anything. Other then that the oil pressure reads as it normally does.
any idea what this could be? i have checked oil level and also have done an oil change and its still the same. could this be causing any kind of damage???
ta
Ash
https://www.sau.com.au/forums/topic/308420-r34-gtt-oil-pressure/
when engine is cold the oil pressure reads between close to 6 maybe a little higher. as the car warms up and gets to normal operating temp it drops to 4. this was before and after so nothing has changed there
Hey Ash, just sounds like the filter filling up. Maybe the anti drain valve in the filter isn't sealing properly? Have you changed filter brands lately?
Edited by scotty nm35
as in oil filter???
if so then no. have always stuck to one filter type which is what ever status tuning put on for me.
youll prop see what i mean when i come this arvo once the car sits there for a little while. but generally does it which the oil is sitting at the bottom of the motor
I know the filters Trent is using and there is a whole thread dedicated to the same issue. I suspect the one way drainback valve leaks on that particular brand (which I am running) and over the space of a few hours drains the filter requiring it to be refilled. Other than that they have a great filter medium inside so im told. If you dont like the startup rattles just try a different brand oil filter, should fix the issue.
hahaha
only happens on startups after car has been sitting for a while. does not bother me muct to at all. just wanted to make sure i didnt f**k anything up or its f**king anything up lol
I does sound like a drain back problem, i dont think it would have anything to do with removing you tappet cover. I used a cheaper jap brand of filter on my FJ without a drain back valve and it made a pretty good rattle at start up, i changed to a ryco, with drain back valve and it cut a lot of the rattle out. You could always spin off the filter and stick another brand or something on there and try that? Easy test and pretty cheap.
G
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drive beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
