Right im now up for a gbox rebuild and i dont wanna stay with standard gears. I've done research on sau and for some reason quite a few ppl have sumthing to say about par gearsets but wont say it. Im considering buying the 1st to 4th straight cut synchro box and would like to hear some comments on what ppl have to say about them. Plain and simply dont be scared if you have run a par gearset and sumthing failed or a bad experience plz tell me about it i dont wanna fork out 5 grand for a gbox only for it to be a waste of time.
thnx everyone
https://www.sau.com.au/forums/topic/308638-par-gearsets/
thnx everyone
dont waste your $$ Simon...OS Giken is the best option for your car.
https://www.sau.com.au/forums/topic/308638-par-gearsets/#findComment-5092611
ok people if you know of blown gearsets etc list the car, type of box if original box or different or any other details that may need to be included like what type of racing they were doing or wat the driver was doing at the time it failed. i dont wanna hear that you know of one i wanna hear real stories.
https://www.sau.com.au/forums/topic/308638-par-gearsets/#findComment-5092913
well as far as i know, the pulsar boys over east have been using par gearsets in there sr20det powered sss pulsars etc and have had no problems
rwd, dont know anyone whos running one but they r a tad expensive comparing to genuine OS giken
https://www.sau.com.au/forums/topic/308638-par-gearsets/#findComment-5092984
in australia for the os giken gearset synchro helical $4199 ebay unfitted/ even worse $5499 just jap unfitted. par straight cut synchro unfitted $3800. tell me how that is more expensive?
the cheapest i found overseas minus postage for the os giken set is actually $3748.
im aware i posted $3400 in post 4 but didnt realise it was in american dollars not aus.
Edited by skylinekid
https://www.sau.com.au/forums/topic/308638-par-gearsets/#findComment-5093183
got a second opinion today off one gearbox diff company ..... was informed dont bother they have had many gboxs blow gears strip teeth etc due to being poorly made and they dont know wat warranty means there. so yeh looking bleek for these gearsets unless theyve picked up there act over the last yr which i doubt. gahhhh ne other opinions ppl
https://www.sau.com.au/forums/topic/308638-par-gearsets/#findComment-5094036
i can get a 2nd hand box for 1000bucks off a mate here but with running near upto 600hp i want sumthing i dont have to replace in 10000kms or less like this one. the box i pulled out of the car was whining sumthin terrible i pulled it apart yesterday and found that the front gear on the cluster shaft has worn off all the case hardness and is starting to go through the actual gear. i got the box rebuilt minus synchros just all bearings 10000kims ago and got all gears etc cryo treated. there has to be a cheaper relaible option then spending 10g on a ppg dog box.
https://www.sau.com.au/forums/topic/308638-par-gearsets/#findComment-5094238
Im afraid you will either have to fork out for a PPG gearset or keep putting in stock boxes.
Im on my second stock box. They are stronger than you think.
It also comes down to how you drive the car, you wont be using 600hp all the time.
https://www.sau.com.au/forums/topic/308638-par-gearsets/#findComment-5094307
my OS saw 600hp a fair bit and was pretty bloody bulletproof...Terry says it all comes down to correct initial assembly and regular maintenance of synchro's that allows them to last.
Terry is the gearbox worlds Jedi master.
https://www.sau.com.au/forums/topic/308638-par-gearsets/#findComment-5094339
I'd say gear wear means the oil cant cope. I use Redline MT-90, but in your special case you should probably give them a call and explain what's happened with the gear wear and ask what they recommend, maybe one of the shockproofs.
https://www.sau.com.au/forums/topic/308638-par-gearsets/#findComment-5094661
yeh im not gonna put the gearbox back in how it is so it doesnt really matter about the oil. its worn the cluster shaft that much that the car sounds like its runing straight cuts. sounds cool but not good wen u realise one day its gonna fail. im just gonna get a secondhand box and probably run either redline or a new oil ive heard of neo synthetic 75-90 very expensive but apparently the ducknuts of oils.
https://www.sau.com.au/forums/topic/308638-par-gearsets/#findComment-5094854
yer my stocker box lasted heaps of time on the street pushing it real hard without a care when slamming gears, but soon as i hit the drags the first pass i swear i took it easy into 3rd and bang smashed the teeth of it. This is a 32gtr box in a 1750kg stagea with a 2.7L running 560awhp. I was suprised how long it lasted on the street the way i was driving, but for some reason the drags were a different story even running the same street tyres.
I went ppg straight cut dog option and its brilliant, fast shifts are simple and firm, its drivable on the road but maitainance costs would make it not suitable and the whine is pretty damn loud except for 4th gear.
https://www.sau.com.au/forums/topic/308638-par-gearsets/#findComment-5095100
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
