Hi all, I bought a aerpro wiring harness for my R34 and I'm using the wiring diagram from here but the wire marked as "O" (Right Front Speaker (-)) is missing from the aerpro harness and there is a blank on that spot. Is this meant to be this way or did I get a faulty one? I wanted to check before I go soldering things up only to find there's something missing...
https://www.sau.com.au/forums/topic/308793-aerpro-wiring-harness-for-r34/
that PDF is from USA , so its not 100% accurate in every type of car/stereo made by nissan, Remember Skylines were never sold or imported to USA till recently so to be safe always test the wires if they don't match up perfectly , you could just wing it... but the airbag or ECU could decide to fire a nasty surprise your way.
clinton,
looking at the back of the plug ( yes I bad that I actually know these pinouts)
spekaers are on the left power is in the middle key is on the right.
rears left rear is on teh right. RT Rear is on the bottom.
should give him a general idea.
(also your prado stuff has a delay - call me on monday.)
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
