does anyone know if i can install a second intercooler on the drivers side of the car ?
i looks like there is room for it but figured if its been done someone here would know about it.
if it can be done can you please direct me to a link explaining
https://www.sau.com.au/forums/topic/308798-r34-twin-inter-cooler/
It does look pretty awesome, but the extra piping will probably cause delay in the air being rushed into the intake manifold.
it does look awesome !!! so your saying there would be more power loss than gain ???
I cant vouch for it, but theoretically speaking the air has more room and more distance to travel. It *could* cause delay. Due to the extra room in there, it *could* cause a drop in pressure as it will take more air to fill the chambers. Don't take what I say as facts, I'm not sure. Someone correct me.
OK when you say delay are you talking off the line drag racing delay (where .5 of a second counts)
because for cooler air i dont mind the slight delay if the end result is more power or punch if you know what i mean , i dont drag the thing its just fun to give it a squirt and i dont want a front mount , after all there is already an oil cooler and a radiator there so i figure use the available vacant space.
it would be good to hear if someones done it and verify what your saying ,
thanks for the advice if its may cause a huge delay and drop power i might think about leaving as it is
Well lets look at it like this, its a common practice to have two sidemounts. It wouldn't be done if there were no benefits. All benefits come with their losses. Bigger exhaust, less back pressure. Pod filter, heat intake. Bigger turbo, turbo lag etc.
But the gains are there. What I mean by delay, is the air has a longer distance to travel through all the intercooler piping before it gets to the piston housing. I don't think it would cause any performance issue once the air is fed through, but again I'm not too sure.
right i get you now
thanks for your help
so the other thing is if i were to do it could i use one off the left of another car and just flip it to fit the other side ?
You are going to have to consider the piping behind the bar. The water bottle for windscreen wipers and coolant are right behind the front RHS of the car. You could use another R34 sidemount and flip it so it mirrors the other intercooler.
You might have to use aftermarket cores (like the two above) if you intend to use two coolers.... If you run much more air volume than stock you will probably find a nasty flow restriction using two factory cores.... if your running stock boost (or close to it) with your stock turbo you should be allright.
You'll have to vent both coolers (air feed AND exit) well to give them any chance... maybe consider a water spray or thermo fans as well.
If you go with a foward facing plenum, it will reduce the overall length of the pipe work quite alot with this style set up.
If you do go with two cores, tap a boost guage into the charge pipe just after the turbo and one just before the throttle body... if you have more than 3/4 psi difference, it's to much or a restriction.
I'm not saying dont do it, but even if two cores arn't a flow restriction, they won't be as efficient and will heatsoak quicker compared to a larger fmic.
More effort, more cost (if you don't do the fabrication yourself) for less result???
Cheers
Justin
Edited by XRATED
Doesn't look like that much extra piping. Especially when you consider some of the other alternatives like a turnflow frontmount on an RB20 or 25. Plenty of piping there.
At a guess it would at least be an extra 30cm, perhaps more because remember you still have to go back to the factory plenum and so on.
So going from turbo --> cooler --> across car --> cooler --> back across car --> upto plenum
Thats fairly long
Cheers
Justin
Im going to take a guess as he is Melb, he is trying to avoid defects... so plenums and things will not really aid the situation.
If i'm right, the smarter way would just be a returnflow FMIC, stock airbox, problems all solved without much hassle.
For the ultimate stealth cooling... just install some 1000cc methanol injectors and pump straight methanol into it ha ha ha.... no coolers required!
Not exactily practical.... but stealthy.
lol yeah im in melbourne and wanna avoid the defects, cops here see so much and an led light and they will pull you over to give the car a once over.
see what i dont understand about the front mount wouldnt it be less affective as the air is heated twice before it hits the radiator (inter cooler then oil cooler then radiator) thats what i want to avoid you know it great to give more power but woulnt it make the car run hotter or has this already been explained before ?
sorry new to turbos !!!!
Front mounts work better in stop start traffic due to the airflow provided by the engine fan. To make side mounts cool well in traffic you would need to install thermos on them which sucks more power than you gain I would guess.
Heat soak may be confined to one intercooler which could help too.
well as i said im very new to it all and im sure youv all had this question a million times ,
i guess ill look around to getting a front mount some time in the future, iv got to change my front bumper first (i have a series 2) will a front mount hide nicely in a series 1 bumper or do i have to go a nismo bumper or something?
Ok so it's as i thought, legalities...
Just put a RETURN FLOW FMIC on... one that uses factory piping etc.
Stick to the factory airbox, then you are 100% legal in that regard with only one intake modification.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
    • Hi, Will the R33 GTR rear brake backing plates fit a GTST? I'm struggling to find GTST ones but can find new GTR ones.   Thanks.
    • I also got the same floor mats for a bit of extra bazzaz haha
    • Some more close up pics now that I’m back to working on the car, the loop pile is nice but again haven’t compared it to the other types in person, it’s hard to tell from the pics on the website. View of the hemming on the edges too, it comes in 2 pieces - front and back, honestly very happy with it for anyone on the fence.  Also attached my previous pics from further up as it didn’t let me post them directly before. (Nothing worse than photo bucket pics that aren’t hosted anymore years later)
