Damo's R32 Gts-r, On Going Project Fun Car. History And Use Full Info
thanks for the kind words guys.
my new rose joints arrived so ive cleaned up the old adjustable JJ arms. and painted the blue ones so they look the same
all ready to go again
After talking to a Man in the know it was decided that changing the roll center of the rear without doing the correct calculations may do more harm than good so my half modified sub frame has been put to the side and i spent a bit of time today doing the small mods to my old sub frame. i also wanted to get the car on its wheels and going in the next few weeks so spastically modified sub frame is on hold again.
In an effort to make the car a bit more subtle for my re-entry to motor sport (i havent drifted anything for nearly 12 months) ive painted the D Max rear wing gloss black to match the roof spoiler.
And the bonnet that looked good on the track actually was a spray can job done over 2 winter nights on the lead up to a drift round. the paint was so wet on the morning that my GF put a hand print in it. so the Gun Mr Chad sanded and prepped the bonnet read for a new coat.
coat of saturn black. the pain was not mixed quite right so were not sure if we will go matt or gloss from here.
and the rear going back together
and a quick snap shot of the track wheels
R34 GTR wheels on the back and 17" CST hyper Zeros on the front.
calipers have been painted silver after seeing a sexy GTR with silver brembos recently. much nicer than red or blue that you see on any old ricer.
i always aim to do more but if im not running the engine in by this weekend ill be sad.
I like the silver subframe and calipers :)
Was it much of a drama getting the new rose joints to suit the arms or are they fairly common?
well if they are imperial (meaning american and speed way useage) they are easy to get but these were metric but turned out to be a common size. i had 3 different brands to chose from and 4 different quality ones to chose from. i got teflon coated middle of the road options as i can aford to replace them many times before buying the expencive shit
the idea behind the silver subfame is not to make it look like a billet alloy one (joke) but light colours show up cracks and oil leaks easy. they also reflect light making working under the car easier.
I painted my engine block light blue for the same reason...makes finding things so much easier.
Ill have to check out what thread my joints are then...
thanks for the info :)
car not has track wheel alignment. race tyres are sorted and should hit the rollers over the next 2 weeks. depends how much time the tuner i use sits in his office on the interwebs.
im pretty happy with the look at the moment so ive taken some pics.
if you look closely in the last pic you can see a riverted carbon panel. its a temporary measure to fix some "body imperfections" untill the wide body goes on.
We took the car out for a couple of hours run in on the weekend. The car's on a very consertive tune ATM, so it'll be interesting to see what it's like when it gets a proper tune.
Great thread Damo the car's looking fantastic. Keep up the good work. Ask your mate if he wants to buy the JZX90 because I want to get an M35 Stagea.
got the car back from the tuner. found some problems that need to be addressed then back on the rollers to see what it will do power wise.
all i can say is wow it has a massive initial punch and comes on strong. the throttles are very noticeable.
bigger turbo time already.
ill be taking it to a club day this weekend to give the car some track time to trial all the bits that have been done over the past few months.
I just realized somthing...was that my old turbo that went bang....I sold you one back in feb 08
Im pretty sure not. it was a Neo turbo that i got of a local bloke who got it off some one off nissan silvia who my have been you now i think of it. who ever he brought it off i got in contact with prior to buying it to make sure it was legit.
I have brought a few other turbos to use on mates cars ect thoe. one of them being a r33 turbo with a blown oil seal for parts.
Ok so a few weeks worth of updates and some more to come in the next few weeks.
so we start with my self inflicted Dyno dramas. first off the car developed a charging issue which i doubted to be the alternator as i had done it up while the engine was out. it turned out to be a plug i had used between the alternator and isolation switch. it had melted due to high current.
i fixed this friday night after doing a few quick jobs on the Porsche i was crewing for in targa. All sweet i though.
than on the saturday morning it developed a cutting out issue. i remembered that we had found that the air flow meter plug lock tab had been broken and the plug kept coming off but had forgotten to repair it before going to the dyno. then the car shut down for a final time and wouldnt start.
When i picked the car up i found that it had a blown fuel pump fuse as during the engine build and subsequent modding the fuse had been swapped over. (or at least thats what im saying)
so i got the car home and started on a list of things to finish off before the weekend track day.
this included fixing the air flow meter plug. the wiring to the alternator and wiring in the air temp sensor in the GTR plenum. then i wired in bens Track Mate data logger ready for the weekend.
i also put in my new second hand oil temp gauge only to find that it didnt work. i had tried it under boiling water before hand thoe to make sure i wasnt waisting my time and it worked fine then.
The knock sensors in the new motor dont seem to work very well so been started to try to remove them ready to replace them with my old knock sensors. he then found that it is impossible to remove them with the plenum hanging off the head. so unfortunately i dont have decent working knock sensors any more.
after sorting out the car we gave the new test pilot the run down on the controls.
so the club day starts off fine with been tweaking the tune ever so slightly. first thoughts of the new engine are grate. then my suspension mans car broke so i offered up a seat. (im very happy to lend a seat to mates as this is a fun car not a greedy car) first lap out and into the second last corner he compression locked the back end spinning him off the track and through a swamp. (well it may as well have been) he continued a few laps then came in and washed the mud out of everything.
during the day i had the car cut out as i was lining up on the start line. i found this to be caused by the air flow meter its self as the plug is now 100% right. So tonight i pulled the AFM apart and found 2 dry solder joints. i fixed them up and put it back together.
it should be on the rollers bey early next week at the latest and i should be able to play with the cam timing a bit as well.
all in all the fun cars back.
Well more self caused dramas on the tuning front.
all sorted for now to get a few events on this new engine.
Car made 200rwkw which is lower than the original 219 bef. but the 2 can in no way be compared which is disappointing.
new power = GTR intake and fresh engine with head work. but also new dyno and smaller turbo (r33 gtst)
old power = original intake. 17 year old engine and r34 neo turbo.
so in the last week ive take the car from this. Track setup and half stripped to remove the mud form the car.
to a presentable Drift Car
and with some help from the trusty ben the cars all most ready to slide or win as he says.
so while every one is at Super Nap ill be at the second round of the state drift series.
well my weekends done and dusted.
Saturday started out ok but half way through qualifying the car developed a miss and was was running on 5.
i qualified 10th out of 18 drivers for the day.
we wipped the plugs out during the lunch brake and one of them was not like the others. so we put a new set in and hoped for the best. unfortunately the miss was still there and i had to retire from my battles. after watching for a bit i decided to start swapping bits off my mates car but still had no luck.
all in all the handling of the car with the cage and seem welding in the front has made it very predictable and the power comes on hard but its lacking about 40kw in the top end.
some modified knuckles are next on the list "to do" after sorting the current issues.
PS: i hate bringing a car home that doesnt work properly.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
