Damo's R32 Gts-r, On Going Project Fun Car. History And Use Full Info
another taken by Bens steady hand. if you look real hard, and i mean hard, you can just see it pop a masive flame on the back straight.
incar will come over the next few days. tomorow if pull apart day.
Well done again Damo, 62.6 is a very respectable time and considering track temp was so low and you struggled for grip only tells us there is more in it!
PS im still waiting for my cheque... or is it in the mail? Lol!
  • 2 months later...
  • 3 weeks later...
bit of an update.
Ive rebuilt the original turbo.
some Injector dynamics 1000cc injectors on the way for some e85 love.
some pics from the last club day i did.
and the flat spot i managed to get.
more to come soon
  • 1 month later...
bit of an update. got injectors in after some dicking around.
modified stock fuel rail to make it twin entry centre out using stock fuel pressure reg.
put it on the dyno and this is the result.
before every one makes their judgments there is a few things to add.
fuel pump ran out of legs so couldnt get enough fuel in the top end. single external bosch.
car was ran in 5th as it wheel spun in 4th
so the number is marginal but it shows the difference e85 can make on an engine. its the same turbo back to back with only the injectors changed and a turbo beanie.
it makes more power, cooler engine, quicker, and with less boost.
upgraded fuel system is the next mod but im not looking to do that any time soon.
few pics to finish it off.
sticker bombed center console and changed switch gear
put mesh in intake to make it appear to have a headlight from a distance.
remounted my carbon pannel to cover wiring.
The front swaybar was disconnected to get better turn, but it did make it wander under brakes. The bar that's in it, is the size of a structual beam.
Yea thanks ben for uploading it. last run was my quickest by half a sec but i think the second last one was the nicest run.
thats on street tyres too. bit of an oversight. i had some better tyres but didnt have the time to change them during runs.
very pleased to get a good run out of this thing.
E85 makes the world of difference to the mid range, it feels far more responsive than earlier this year.
im pretty rusty in the driving department but i was only there to have a bit of fun. and like ben mentioned having no sway bar tends to make it dance under brakes.
Got the final round of the tassie drift series to go to this coming saturday so will see what it can do there.
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
