OK scenario... 10" wide guards, and only 9" wide rims, meaning rims woul be an inch inside the guard.
Firstly can you use spacers to being the wheel out to sit flush with the guards
and secondly, how far out can it go, ie can it be brought out about 2 inches or so? (Trying to fit regular GTSt rims under a GTR front guard without having to change rims.)
Thanx 4 ur help
I have used spacers in the past with great results. The car felt much more stable in corners too.
Just be sure to get HUB CENTRIC spacers. These are designed with an extra little lip which make them safe to use. The spacers I bought were very expensive, german H&R hub centric 15mm fronts and 20mm rear. Car looks fat!
Hmm its either that or I buy a set of Work Rims for a GTR... hmmm I'm lookin at bringing them out about 20 to 24 mm so dunno if its worth the hassle.
  • 6 months later...
Just reviving this thread as I am interested in getting 5-10mm spacers for my GT-R to make it LOOK that much tougher.
A) I know spacers are defectable but they'd never look there. Spacers don't tend to stand out too much visually.
B) So long as they're hub-centric and also bolted on to the hub they're safe.
C) They won't necessarily stuff up your geometry. In fact, according to tests with spacers in OPTION Magazine they will make your lap times FASTER. Yes. I have the magazine where they test different width spacers on track and record their lap times and times were reduced with spacers on. Now that's some good real world testing which cleared things up for me as I know my last car felt flatter through corners with spacers on.
You are limited to an extra 20 or 25mm (can't remember which) of track width, which is centre of tyre to centre of tyre, not outer to outer, but are also limited tyre width wise.
Increasing the track increases your scrub radius which puts a little extra load on the steering rack, but shouldn't break anything, and certainly won't upset suspension angles
I must not be drinking as much as i used to, once upon a time i would never have remembered something from thsi long ago :( See here for what may fix your woes provided you dont co crazy with track increase
Why are we always lurking in the same threads Roy? I can look at a topic and bet myself that Roy will be there soon or has already been and I always win :rofl:. Wish powerball was that easy.
Anyway that linked thread also discusses welding of wheels which is covered under Vic Roads website and is legal according to the standards, but back to topic, blocks are legal, spacers are not (the not bolted in things) as they limit the thread capture for the nut and a whole heap of other things us engineers talk about to confuse people.
R32 GTR's definitely need about 10mm per side as they look silly on standard wheels and all that guard overhang.
Why are we always lurking in the same threads Roy? I can look at a topic and bet myself that Roy will be there soon or has already been and I always win :). Wish powerball was that easy
LOL, i think its because we happen to think along similar lines and share same approach to modding a car...sorry to say Geoff but you may need help, the kind you can only get from a prefessional, ive already seen a few and there is no helping me, but we must hold onto our faith :rofl:
Im all set to try some spacers if my new but wider track rims dont fit all that well :(
I'm looking for about 25mm spacers for my R34 GTR rims on my R33 GTR, they need more offset :D
$500 bucks for jap bolt on ones... can anyone give me some advice? can i get them cheaper/better?
Hey man i also had to get bigger spacers becasue of my wheel size on my cef, 17x9.5s. Yeah they stick ou like 5mm. :wassup:
cost me 200 bux for a pair of 21mm spacers. Here in sydney.
U have to send em your rim thou to match. (since your in vic)
Name: Neale Wheels - (02) 9642 1002
Also had to get longer wheels studs as well. 75mm size for 6 bux each as well.
Let me know if u still want to get some done. As i know of a few places to look for in vic.
ceffo.
your hubs and wheel stubs and studs are usual engineered for a certain amount of stress .. hence the max of offset ppl use and what wheels are manufactured to
.... there's a point where u have too much offset and your suspension suffers greatly ... look at buying wheels with more dish .. like a +9mm offset .. as standard is about +27mm or is it negative .. i forget ...offset your rims .. not your studs
spacers are a no no ...generating more lateral stress on your stub and wheel bearing .... hence shorter life span in that regard.
MT
  • 4 months later...
time to do some digging out of an old thread...
there is a guy that has 18x8 350z track rims - I'm considering whether they'd be good for the GTR with 20mm spacers as road wheels.
What's the widest on a 8" rim? 235 I'm assuming
Geoff / Roy - what do you think of this?
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
