hey looking to upgrade my turbos on my rb26 what would be a good upgrade trying to spend as little as possable i have seen the n1s but been told not much more power than stock or if you are selling any let me know?
https://www.sau.com.au/forums/topic/309234-turbo-upgrade-for-32-gtr/
cheapest bet is to buy a rebuilt pair of stock gtr turbos with steel exhaust turbines - can be done for around the $1350 mark from a bloke in Melbourne I know. PM me if you want more details
-D
yeh a guy on ebay got n1 turbos with all gaskets for 1350 on ebay thinking that
thats a good deal... kits like that are pretty painless to fit (as far as turbo fitting goes that is), you might need to buy some new lines and studs maybe but once bolted up, all you should need to do is push more boost thru - do u have an EBC?
-D
Edit - incidentally, the N1's will give you that extra power, as they can be boosted past 14psi, right up to 20-25psi (not sure when they run out of puff)... stock gtr turbos are limited to 14psi and only produce 180-220kw safely... you'll easily make 300 with N1's, maybe a bit more... if you wanted more power tho, you'd need to consider 2860-5 turbos or some GT-SS/GT-RS - theyre very similar, it all depends on what is more important, a high dyno number or drivability and response
Would have to disagree with the above, Before purchasing mine I weighed up all the options between the -7 and -5 set up's and eventually went for the -7(N1) turbo's and was extremely happy with the result. The car made 314rwkw and came on boost like they were still standard turbo's (absolutely no lag). -5's won't make alot more power maybe 30-40rwkw but they will definetly increase lag unless your planning on running aftermarket cams etc etc.
If I understand it correctly the Garrett turbos relate to the following Nissan & HKS turbos:
2860-7 = Nissan R34 GTR N1 (although there are 3 different N1 models)
2860-9 = HKS GT-SS
2860-5 = HKS 2530
The HKS GT-RS are much bigger turbos and from what I have read on SAU you really need a stroker kit (JUN 2.7, HKS 2.8, OS Gikon 3.0) to avoid massive lag.
The following graph & chart may be a useful guide but are a few years old now.
Mine has made 326rwkw on N1s... but would say definitely save up and go garrett 2860- 5s
+1 for -5's
b/c u'll have room to get bigger kw down the track with supporting mods
without the need to upgrade bigger turbos
from memory gt-ss = -7's
twin gt3071r .64 on 3ltr bottom end :P
you're a baddy :P
    • Long time no random post about shit. So I went down this deep deep rabbit hole of battery storage for the home, ended up locking in a 41.9kWh Fox ESS EQ4800 with 9 units stacked. Battery uses Lithium Iron Phosphate, similar to what you find in those deep cycle boat/caravan batteries. And yes, why did I go with a cheapie brand and not like Synergy? simply because I don't plan to stay at this house for more than another 3~5 years.  The entire install, DC coupling (removal of existing invertor, connecting the current 6.6kW array direct to the battery invertor), new 8kW invertor is $6K all up (after all the rebates etc.). Going with this lot: https://www.aussiesolarbatteries.com.au/ It did seem a bit too good to be true, however seems like the Whirlpool community has vetted it and when it comes to this kind of stuff, they seem to be all over it: https://forums.whirlpool.net.au/thread/9pxj8482?p=38   I've requested for the battery to be installed outside, next to my meter board and not inside - rather have it combust and ignite outside lol.
    • In Vic it would be a defect regardless of whether or not you cut a hole in the sheetmetal for the return pipe. The rules in Vic are shitful, and are generally interpreted as you can "make 2 mods to the intake system". Putting an FFP and an FMI onto it will almost certainly be seen as some huge number of intake mods. You really need to speak to an engineer before doing this stuff in VIC.
    • planning a r34 rb25 de+t with some other work, rather just have it done in a shop due to space limitations any recommendations? I have most the parts already I seen online Moore Performance and DR Drift any advice appreciated thanks
    • I’ve read the previous posts so just looking for latest information on how people have dealt with front facing plenum is it a defect etc or didn’t pass roadworthy or was it not noticed? Have a r34 and deciding if I should make a hole on the driver side or not.  I know some people have said blitz return flow but I might get rid of the stock intake down the line for a plenum so I rather set up for that now plus I already have a standard Intercooler. Car is mainly stock  Thanks.
    • Actually, if having and keeping the stock ECU is the plan, the correct answer is to put Nistune into the ECU and improve the situation, not just look at it.
