I am up for a registered and reliable car that will be fun on the track. I like Skylines (because I can fit in one) and at $18k it is much less of a write off worry.
What needs to be done? Suspension and tyres are a start. Are the brakes ok? What about the stock intercooler. How much weight could you get out of one? Power levels would be kept lowish for reliablity.
Anyone with experience of their own car?
https://www.sau.com.au/forums/topic/3093-r33-gts-t-as-a-track-hack/
Originally posted by peteSmith
go an r32 gts4 and drop an rb25 det in it.. you will have a greater advantage due to less weight in the r32 (the 4wd might even it out) and way better handling with the ATESSA.
Just let you know it dont work... :D
but if you put RB26DETT then It'll fly! :P
cheers
Joe
Go the R32 GST-t Type M.
It's got R33 GTS-t brakes, without the extra weight.
4WD is good, but can be troublesome. If it is a track hack, then RWD is the way to go as any 4WD will understeer. Also cheaper to fix if something goes bang inside (which is very likely).
Any car with suspension and brake modification will have a very distinctive advantage over cars that have engine mods only on the track. Arrive at corners sooner but having to brake earlier and losing time through corners because you cannot balance the car and keep it on the racing line, vital time will be lost.
Tyres, as usual are also vital. Get a set of slicks and you'll be very happy.
Engine swaps and things go against the whole reliablity aspect I am after.... With the R32 or S13 the oldness factor goes against it for me. Am I wrong in thinking that?
Also what is the difference with the 4WD blocks. I presume the front left driveshaft goes through the sump or something.
I was thinking R31 coupe with RB25DET myself. Dedicated track car makes it much easier - no rego, no interior etc etc The guys at Powerplay can get hold of em cheap.
No so handy for cruises tho.
I would have it as a dedicated track car, but still with rego and stuff, for convenience. I don't have a tow car or a big workshop. Also it is much cooler to turn up and whip people's arse in the car you came in...
Personally i like the idea of a dedicated track track car as distinct from your daily or road car, it works out a hell of alot cheaper. Apparently somewhere sells things like R32 GTSt for $6K (was in TP), imported as race cars unable to see the road. Something like that would be great to throw minimal amounts of cash at and the financial risk of destroying the thing is minimized....
If you have a rego'd R33 its still going to cost you $18K give or take if you have a big moment at the track??
Guest Impul 25T
If you are looking for cheaper, get an R32GTSt typeM (with the bigger brakes) and put an RB25DET in it. Will still cost you less than a 33, plus have a lighter car.
As for removing weight in the 33, depends on how crazy you want to go. There is atleast 50kg's of tar sound deadening on the flooring, plus other stupid things like aircon, back seats, etc. Also, in between the rear seat and battery compartment, there is a really heavy metal divider plate. Replace that with some Aluminium or something and you'd save heaps of weight there also. Plus the 100,00km's of unnecessary wiring too......
$18k of GTS-t is much better than $55k of GT-R, it's all relative I guess. I go to plenty of sprints and see dented $220k 911 GT3's.
At least a GT3 will take the punishment and keep coming back for more. I have discovered GT-R's aren't quite as tough on the track as they appear on the road. Even with only minor mods.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
