Hi guys,
I am finishing up converting the front of my NM35 RS to the PM35 Autech 350S but am having a little trouble with the grill.
Basically, getting the complete OEM Autech grill from Nissan Japan would cost me just over $1k (!!!!!!!).... needless to say, it ain't happening.
What I would like to test out is if the NM35 Axis grill will fit (same top clips and bonnet ornament, just not sure if there is a difference in width between the two grills).
So if there are any 2001-2003 M35 Axis owners in Melbourne on here that wouldn't mind me bringing my car to test the grill size, please let me know.
Edited by iamhe77
https://www.sau.com.au/forums/topic/309321-m35-axis-owners-in-vic/
I have a C34 grill.....should fit up OK.....same aren't they?
Couldn't help yourself could you?
Custom stainless grill ftw, to go with the shiny wheels. :(
Dunno man.... with the way you go on about weight saving, wouldn't aluminium be better? :P
Ok, since I have couldn't be stuffed reading through all of the responses from all the Vic Axis owners, can I ask that ANY M35 Axis owner possibly lend a hand and measure the width of the top and bottom of the grill and also the width of the bonnet ornament?
I just replaced all my front end a couple of months ago. I will ring panel beater to see what is left over.
From memory grill was about $700 mark the lights were $2k each.
Some one else's insurance was paying so who cares about shopping around.
Yo what scotty said custom stainless grill FTW organize a group buy I already got the shiney wheels.
Edited by boostedaxis
Yeah Mark, the prices for the grill assembly are just a tad high I think.
Could you possibly measure across the front of the top and bottom of your grill for me?
I can get an NM Axis grill with bonnet ornament for around $300, but I need to know if it will fit.
Sorry... what? WTF!?! 2K EACH? For the lights? How is that even possible? Were they just skimming some money off the top cos it was an insurance job? I would've figured max 1K each.
Sounds about right.
I call a couple of Nissan dealerships for a price on the series 2 Xenon headlights.... $2.5k each.
No skimming buddy. Two words for you JUST JAP. It was an $8000 repair 1 headlight 1 grill 1 bumper small repair and paint on the bonnet. What ever you do dont crash an axis.
I will measure up for you when the missus gets home this arvo.
Cool, thanks :ninja:
that's exactly what happened to my car when some dick reversed into me. Thank God it's covered by Shannons. 1 headlight, 1 front bar, 1 reo bar, grill, minor repair on the bonnet. All up about $6000 but headlight is not new as there's none from Nissan Japan atm, so I bought Cam's 2nd hand set :ninja:
Btw Cam I got the lights, so thanks!
Ok done measurements for you.
First one is top to bottom vertically straight up the center bar = 175mm
Second measurement is across the top of the grill= 970mm
3rd measurement is the lower length that was hard to measure because of the curve. I measured it across the lower horizontal bar on the grill =850mm
Thanks for that Mark.
Seems that it will not fit as it is ~80mm wider than the Series 2 Axis grill.
Oh well... grill-less for a while longer I guess
Ive got a sheet of ally here with your name all over it, for when you change your mind. :)
You can drill all the holes tho, or laser cut Nismo into it? :devil:
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
