. . . sometimes I think we always want what we have'nt got . . . but on this occasion I think the Red is sweet.
I have'nt seen ours (its Red) for about 3 weeks and I think it will get a blast tonight.
So thanks - 09 GTR - for the Motivation!
https://www.sau.com.au/forums/topic/309540-photos-of-09gtr/#findComment-5104985
Its my pleasure. I know what you mean, every time I see a Gun Metal Grey one I wonder if I made the right call. I do find Red paint quite sensitive to swirl marks etc, but in the end I figured that if I'm going to spend 150 + on a performance car it needed to be red!
https://www.sau.com.au/forums/topic/309540-photos-of-09gtr/#findComment-5105141
the red looks tops mate, i have a thing for red nissans. perhaps its a little 'pack of assholes' in every one of em.
paint maintenance is a must with any red car, be sure to wax it as often as humanly possible :cheers:
https://www.sau.com.au/forums/topic/309540-photos-of-09gtr/#findComment-5107357
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
