  • Replies 234
Posted Images
Just plug it into the OBD2 port and it will turn off with the ignition. :D
WRONG! lol sort of.
its not as simple as just plugging it in. if u plug red to red, the Touch stays on.. if you plug the Red to Orange, it will turn on n off with the ignition. make sure its red n orange.. u dont wanna short something. the orange wire plugs into your ACC power.
i think the ciggarette light is an addition to the non OBD readers..
Scott gave me the heads up before chopping. but yeh it says it in the book in the english part
mmm ... I don't think so ... I have had my Informeter working perfectly in my car for 6 months..
It is just called reading the Instructions.
maybe the later ones are wired different. i should take a copy of the book and upload where it says this
later models???
Back of the book in English it show's you.....you should have additional wiring attached to the plug....just plug and play. Mind you I have done mine different to Andy....I have a switch in between so I can turn it off and on!
Edited by Jetwreck
later models???
This is what my book says, i dont know if its different, not much point in buying two to compare lol
Says Red to Red, may drain the power because instead of turnin off with the ignition, it stays on, and after some time goes into stand by. not really good for your battery.
the image that says red to orange- it will turn off with the ignition. Notice it also says for NISSAN and subaru..
I dont know. ide rather follow the book. plus being a sound engineer, i know what damage power draining can do to battery cells, and units that are sitting in stand by for extensive times.
Craig- your idea of having a switch is pretty good. It would break the circut not draining poower at all..but what would be the reason to turn it off while your driving?
and one other question, My injectors hit 94% yesterday. should i consider bigger injectors? whats a forum for this infor for injectors that fit without plenum raising it(i like the cover so i wanna keep it)
cheers
Edited by AaronNM35
cheers
that's quite high....whats you AFM %?.....should be about 4.8%. You should start looking at doing the whole fuel pump, ECU and injector thingo! It's painful not having a car! :(
Looks like another Emanage install is in order. :)
Any of the 350z injectors will be plug and play. Plenty in the states on fleabay.
lol you really want me to put this emanage in dont you lol
ill have a look on 'fleabay' oh n what size injectors should I get 550cc will be enough? whats the stock?
i didnt take note of the air flow.. ill keep an eye on it driving home from work.. this means calm driving :( .
CRAIG GET A NEW ENGINE IN ALREADY!
n fuel pump? where the bloody hell am i gonna fit that.
Edited by AaronNM35
The second page of the instructions shows pretty clearly (IMO) that you connect Red - Orange on Nissan ODB cars and do not use the cigarette lighter.
94% injectors, nothing yet.. wait til you hit 100% lol.. You can set an alarm on the Injector so you know when you are in the danger zone. Mine is set at 95%. I usually only see 100% over 7000rpm.
What you need to know is if the AFR's are Ok. Get a Dyno run done to see what sort of tune you have going on.
Cheers
Andy
Cheers
Andy
yeh mines connected red - orange. Ok now Im confused about what the debate is on :( lol forget it, it works!
um yeh i have an alarm set for 95% aswell just so i pull my foot off the accelerator lol
hopefully the AFM% is at 4.8+- like craig says. other wise im fecked.
Dyno run? for a AWD? in Melbourne? ill have better luck finding a unicorn than to find someone who wants to do a AWD Dyno for less that $600.00 lol
motor is about a 2 weeks off! :)
Talk to Scott about the dyno when you get a second....wouldn't say you have a problem above 4.8....mine ran at 5.0 for a very long time....and that wasn't what blew my motor!
Hey, if I can get one done in Adelaide for $90 Im sure you can get one done in melbs :( Might be worth asking if the SAU:Vic chapter is planning a dyno day any time soon, good way to get a cheap run in for the sake of checking numbers if you dont wanna spend too much cash on it (SA dyno day was $40 for me (non member), same place would normally charge me $90)
Customs have my informeter, I think.. Bastards.
I pay $50 an hour now, and local... :(
yeh but does that guy still do it? i thought u said he left it n only doing urs.
craig- 2 weeks away is alright, at least this time you'll know to listen to warning signals. lol
Dunc - i'll get scott to help me find one, live 5 minutes from me. Customs? what do they think theres drugs in the plug or something.
Better hurry, he is selling the dyno soon. RE want $100 an hour now, what a rip.
RE's dyno is shit house aswell.. i remember seeing something about it being 20KW out or something.
$100 an hour for a useless company is stupid. i will NEVER take my car there.. a bunch of stuck up twats that dont know anything.
Sounds like you have been listening to Scott a bit too much there Aaron!
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
