  • Replies 234
Posted Images
I just got an email from my contact in Japan who can once again get me some informeter's at a very good price. (sorry Dunc & Dale)
let me know if anyone is after one?
Cheers
Andy
Hi Andy, can you PM me info on the infometer?
Thanks, Leon.
It finally showed up, in a very well traveled looking postage satchel with no padding :|
Everything looks to be in order, no damage to the box or the components.. looks like its all there and brand new. Fingers crossed theres no dramas!
I'll see if I can photograph some of the setup/install and screen options for this thread (and M35Stagea.info) :) I should really learn japanese; the manual has 91 pages of documentation for them, and 20 for us. Im pretty sure their language isnt THAT inefficient, so Im guessing they just get more details... bastards!
Got around to installing it, the missus came over and wasnt too keen on me sitting in the car for 30-45mins last night :P
Never mind, I had a good think about where would be practical for the unit and initially tried zip tying it on the right hand side of the steering wheen; that proved to be an awesome sun light reflector in to my face - so I settled for it on the left hand side.
The display itself is nice and clear, very easy to read
I used the double sided tape to mount it, wasnt possible to get it completely flush but I think it should hold
Didnt take any photos of the wiring, but I went with the Red - Orange connection, turns on and off with the car. I tucked the cables up into the opening in the panel next to the OBD plug, havent cable tied/taped back the cables flush yet but its out of the way for the time being :rofl:
Hi Dunc
Nice job.
That is the same spot I put mine. You should be able to tuck the cable up next to the main console next to the air vent.
I managed to bend my mounting pad so it sits flat on the curved surface.
Cheers
Andy
Hi Dunc
Nice job.
Cheers
Andy
I contemplated trying to bend it but figured Id probably some how break it, knowing my luck :D
Theres already a cable running down there for the fog lights, I'll sort something out eventually.. Im thinking those little square stick on patches with tiny cable ties built in; one or two of them should keep it nice and flush.
Interesting thing I was oblivious too initially, the branding on mine! RE雨宮 (RE Amemiya), as in the tuning house for rotaries. Weird. Everything was new, in box. Protective plastic film still over the screen. Who knows :)
i rekon the mishi would have fitted with some cutting
but these ones have the mounts in the wrong spot and they hold the AC condenser out 10mm away from the core so the entire unit doesnt fit in
anyway, it will be sorted with more time and money thrown at it :P
Thats about how far the condenser sits out from mine...
how did you get it to fit without cutting too much of the reo away?
bah, dont worry actually. gotta get the radiator modded anyway so ill get them to move the mounting points forward so it WILL fit
then ill just shorten the hoses on the back so they dont kink up
    • Hi All,    I have my BW EFR 8474 with a T4 split 1.05 rear housing. Rear housing is ceramic coated and drilled and tapped for EMAP take off.  Supported 520awkw at 35psi through the 8HP with ~5k rpm spare on the BW 127k limit. Ran a 9.98.    Turbo is one of the first that was released but only done ~3k kms.    Asking $2800 happy to negotiate. Only selling to upgrade.   Located Gladstone QLD happy to ship.
    • Hi is the Toshiba sceeen still available?
    • Just wondering how come the hood was grinded down?
    • I have no hard data to report, but I have to say, having driven it to work and back all week, mostly on wet roads (and therefore mostly not able to contemplate anything too outrageous anywhere)..... it is real good. I turned the boost controller on, with duty cycle set to 10% (which may not be enough to actually increase the boost), and the start boost set to 15 psi. That should keep the gate unpressurised until at least 15 psi. And rolling at 80 in 5th, which is <2k rpm, going to WOT sees the MAP go +ve even before it crosses 2k and it has >5 psi by the time it hits 90 km/h. That's still <<2.5k rpm, so I think it's actually doing really well. Because of all the not-quite-ideal things that have been in place since the turbo first went on, it felt laggy. It's actually not. The response appears to be as good as you could hope for with a highflow.
    • Or just put in a 1JZ, and sell me the NEO head 😎
