  • Replies 234
Posted Images
I just got an email from my contact in Japan who can once again get me some informeter's at a very good price. (sorry Dunc & Dale)
let me know if anyone is after one?
Cheers
Andy
Hi Andy, can you PM me info on the infometer?
Thanks, Leon.
It finally showed up, in a very well traveled looking postage satchel with no padding :|
Everything looks to be in order, no damage to the box or the components.. looks like its all there and brand new. Fingers crossed theres no dramas!
I'll see if I can photograph some of the setup/install and screen options for this thread (and M35Stagea.info) :) I should really learn japanese; the manual has 91 pages of documentation for them, and 20 for us. Im pretty sure their language isnt THAT inefficient, so Im guessing they just get more details... bastards!
Got around to installing it, the missus came over and wasnt too keen on me sitting in the car for 30-45mins last night :P
Never mind, I had a good think about where would be practical for the unit and initially tried zip tying it on the right hand side of the steering wheen; that proved to be an awesome sun light reflector in to my face - so I settled for it on the left hand side.
The display itself is nice and clear, very easy to read
I used the double sided tape to mount it, wasnt possible to get it completely flush but I think it should hold
Didnt take any photos of the wiring, but I went with the Red - Orange connection, turns on and off with the car. I tucked the cables up into the opening in the panel next to the OBD plug, havent cable tied/taped back the cables flush yet but its out of the way for the time being :rofl:
Hi Dunc
Nice job.
That is the same spot I put mine. You should be able to tuck the cable up next to the main console next to the air vent.
I managed to bend my mounting pad so it sits flat on the curved surface.
Cheers
Andy
Hi Dunc
Nice job.
Cheers
Andy
I contemplated trying to bend it but figured Id probably some how break it, knowing my luck :D
Theres already a cable running down there for the fog lights, I'll sort something out eventually.. Im thinking those little square stick on patches with tiny cable ties built in; one or two of them should keep it nice and flush.
Interesting thing I was oblivious too initially, the branding on mine! RE雨宮 (RE Amemiya), as in the tuning house for rotaries. Weird. Everything was new, in box. Protective plastic film still over the screen. Who knows :)
i rekon the mishi would have fitted with some cutting
but these ones have the mounts in the wrong spot and they hold the AC condenser out 10mm away from the core so the entire unit doesnt fit in
anyway, it will be sorted with more time and money thrown at it :P
Thats about how far the condenser sits out from mine...
how did you get it to fit without cutting too much of the reo away?
bah, dont worry actually. gotta get the radiator modded anyway so ill get them to move the mounting points forward so it WILL fit
then ill just shorten the hoses on the back so they dont kink up
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
