hey guys im ordering a set of xd9s for my gtst
18x9 +30 and 18x10 +38
ive got gtr front guards so i no the front has no problem sticking out
but im just worried that the rears are going to be sticking out of the car
too much...
is 10 inch for a gtst too much?
my other alternative is to get my guards rolled add camber so it look like its stil under the guards
cheers everyone
https://www.sau.com.au/forums/topic/309783-work-emotion-on-r33-gtst/
They wont stick out at all, you'll find that they will both be way inside the guards.
If you get 18x10 +18 for the rear it will be a perfect fit, you will just need the rear guards rolled. As for the front you have GTR guards so im not quiet sure what they will fit?
yeh with gtr guards you'll want +18 on the front but all same size on gtst duno about that..
disclaimer: flame all you want about my weak offset or wrong tyre choices or w/e. i dont mind im jsut giving old mate some info:
i have CR kais, 18x9.5 +38 front and rear. I fit a 275/35 on the back with rolled guards and 2.2degrees neg camber
fronts i have a 10mm spacer cos the spokes didnt clear standard gts-t brakes, tyre is 245/40 with 1.5ish degrees neg camber and no guard mods (gts-t guards). lowered to sit about ~1cm between guard and tyres all round and its just touching the corner of the front tyres, any of a A:very light roll or B:halfa degree of camber or C: a 235tyre would all sort that easy imo.
my 2c
-Sean
edit: just to be bleedingly obvious NO that isnt them in my sig pic :P
Ohh ok sweet :blush: the only
offsets I can get from work is 30 fronts 38 rears
or +18 all round but the + 18 is 2240 with out tires the +30s are 2500 with federals
all round I think I made my mind up :D
Ohh ok sweet :) the only
all round I think I made my mind up :)
that is the most ridiculous thing i think ive ever read..
its cheaper but will look like shit so ill buy it? :down:
give ya a free tip its cheaper cos its no good you get what you pay for remember.. 18x9 +30 on GTR guards is a really bad idea man you'll regret it straight away go +18 just hunt out second hand with tyres if budget is a concern or save up more.. take advice from billy :)
Just to be sure lol but you know what
because of what you guys said I've decided
so ditch the cheap pair and buy the more expensive ones
with the better offsets :)
so now I'm looking at 18x9 +20 , 18x10+18
or
18x10 +18 allround
and I want to be scraping at wheel lock or when I have full load
so I'm leaning towards the 18x9 at the front
does that sound better everyone!!! Lol
now just need help with tires
alr33x dude I'm listing to you lol
ask billy re tyres but i think he runs a 245 on the 10s on the 9s you could go a 225 which isnt much stretch at all, i dont think you would scrub on full lock with the 10s gtr guards are huge my arches only cop a belting cos it sits lowif i raised it 10mm or shaved the inner lip of fibreglass would have no issues
id still say the 10s will be a nicer fit with gtr guards..
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
