  • Replies 76
Some developments:
Got a workshop to take a quick look at the car, they chucked it on a dyno briefly. Turns out that it's an internally gated turbo with the gate welded and routed to an external gate. They blocked off the wastegate so that theoretically the turbo should have boosted until something blew up but it had no effect whatsoever!! Something is screwed up, I'm going to get the whole setup looked at.
My friend also spotted a small rubber blockoff coming off the turbo which had broken. We put a new one on and it's now boosting a few hundred RPM earlier which is nice.
Also did a bit of road testing, the car is showing positive manifold pressure as low as 2800rpm, but only 1 or 2 psi.
I'm going to get the air filter relocated back under the bonnet, its gets wet being where it is.
  • 4 weeks later...
Found out the turbo is a KKR480 (or at least a copy of one), my tuner reckons that its pretty hard to get much more out of the current setup. So once I sell my old car, the series II is going in for a new turbo. I've since had the AFM/pod moved up into the engine bay (so now the tune is screwed as well :) ). He is pushing me towards a GT35 with the 0.63 housing, but I'm not convinced. I dont plan on rebuilding the engine so I would rather have a smaller turbo with less lag being pushed a bit harder. I will also be getting all the stupid blue silicon hoses replaced with proper stainless pipes, and I'll be getting a catch can put in.
Found out the turbo is a KKR480 (or at least a copy of one), my tuner reckons that its pretty hard to get much more out of the current setup. So once I sell my old car, the series II is going in for a new turbo. I've since had the AFM/pod moved up into the engine bay (so now the tune is screwed as well ;) ). He is pushing me towards a GT35 with the 0.63 housing, but I'm not convinced. I dont plan on rebuilding the engine so I would rather have a smaller turbo with less lag being pushed a bit harder. I will also be getting all the stupid blue silicon hoses replaced with proper stainless pipes, and I'll be getting a catch can put in.
you are taking a turbo capable of 400kw and putting a restrictive rear housing on it that makes it struggle to make 350kw and is laggy compared to a 3076 which makes a tad less power with lots more response.
If the car is seeing positive boost pressure at 2800rpm and the turbo will not boost any higher I think you have other issues. Its a pity the performance place couldnt help identify anything. The turbo could be fine, sure a GT3076R would be better but doesnt mean the turbo on there cant work well. Would suck to buy a new turbo and then find out the issue is still there. Although I cant say what tests to run, hopefully some other people on here can help with that.
Hmmm so its got to be something that restricts the turbo as it spools up but still allows it to get to a nice peak power. hmm
Yup -1 for the GT35R with 0.63 housing, dont do it.
Edited by Harey
Thanks for that, I'm probably asking stupid questions haha. I wasnt keen on a GT35 in the first place
The mechanic said he's fitted several KKR480's, all with much the same result as me, although I had a slightly better top end which he said was probably due to the aftermarket plenum. I would rather sell the turbo on it and start again with something better (I am not really out of pocket as I bought the car with this setup on it).
I've just read the entire thread, and it sounds like you obviously purchased the car as is.
Have you by any chance checked the exhaust system thoroughly? Is there a shitty compliance cat in there? Has the cat begun to melt? Has a muffler collapsed?
What I'm highlighting is significant exhauist system restrictions can easily cause you issues.
Nah, it has an xforce 3 inch turbo back, and the cat was replaced with a high-flow 4 inch item just before the turbo was put in. It used to be my workmates car, so I have at least some idea of whats gone on with it in the past.
Would an exhaust restriction cause it to hit positive boost pretty quickly, but then boost slowly and still make a good peak power figure?
hehe my xforce 'high flow' cat filled up with crap and sort of fused itself towards one end of the shell due to my Microtech not running an 02 sensor and running excessively rich, it would probably be worth checking out to eliminate the possibility, especially if the car's had a really crappy tune at some point.
Im running gt3076r with 50mm gate on stock manifold on 19psi and making 390rwhp
fullbboost at 4100rpm and pulls to redline
u can pickup a new gt3076r for around $1495 from garrett
drop the exhaust and see if the restriction is there... your tuner probably should have suggested this.
I run a hks 2835 (garrett 3071 based turbo) and see 20psi by 3400 revs and make 390rwhp (432rwhp on e85)
a 3071 /3076 is what you are after... (but either way a 30xx turbine housing)
anyone suggesting a GT35xx turbine for someone after response and sub 300rwkw on an unopened RB25 has no idea / or a good deal on a gt35xx that they want to flog
i'd reccomend a new tuner
Difficult to promise a yes answer as there's lots of levels of "restriction", but as a whole I would definately say yes.
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
