Hey guys just brought some LMGT4 rims.
Sizes are 18x9.5+30 and 18x8.5+25
Anyway just wanting to know about nut for them, there is very limited space for my current nuts and the socket so I was wanting to know how to go about getting nuts that will fit properly but I don't know what to look for in terms of length, width, 15mm etc etc...
Thanks for your help.
Ross
https://www.sau.com.au/forums/topic/309973-wheel-nuts/
I bought myself some McGard wheel nuts. They're quite expensive but they're really sturdy and worth the money.
http://www.mcgard.com/
comes with slim sleeve locknut tool - the catch is it's imperial 13/16" so our metric socket provided in the car may not fit - but there's autobarn for all socket size u need...
I had a look at a few JDM option but those aluminium lightweight nuts from the likes of 5zigen seems like they don't have enough strength since they're so light. tru or not i'm not risking to find out seeing my wheel fly off to a cliff while i'm balancing three-wheels into a chicane!
https://www.sau.com.au/forums/topic/309973-wheel-nuts/#findComment-5108589
The key on the Mcgard are not that strong and a over enthusiastic spanner monkey with a trigger finger will rip the head off of it in a bout .1 of a second and tell you in no uncertain terms your nuts a tight!!!! hummmmm tight?????????
Thankfully there not that hard to get off without the key either if you have the right tools
https://www.sau.com.au/forums/topic/309973-wheel-nuts/#findComment-5108617
only tools with their tools use power tools on McGard (or basically any non-OEM nuts)
it is clearly stated in the McGard manual NOT TO use power tools. you will find the same power tools are not recommended even on other brands, so it is not a fault on McGard quality or workmanship.
I bought a socket and a wrench from local parts store. that did the job to replace the stock jack wrench.
use hand to tighten or untightened the bolt, leave the powertools for the shitboxes
https://www.sau.com.au/forums/topic/309973-wheel-nuts/#findComment-5108621
Appologies Theres a lot of tools where I come from trust me
half of them think the actual air gun can torque up the nuts coz it clicks init when its tight mate and then check with a torque wrench AFTER
err nice!!!
Now try to explain to them that they now could have stretched the studs and a blank look followed by yeah mate its metal you carnt stretch metal will fall out of there mouth
https://www.sau.com.au/forums/topic/309973-wheel-nuts/#findComment-5108641
Rays wheel nuts any good?
they're the cream of the crop - very light, quite strong - 4 locknuts + the other 16
i still take my slim socket + wrench around with me though; so it'll fit between the nut 'n wheel
best not to use the rattle gun with these too > torque wrench set to 108 nM.
https://www.sau.com.au/forums/topic/309973-wheel-nuts/#findComment-5108816
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
